N54 Colling System Water Hose Adapter
05-25-2019, 01:15 AM | #1 |
Rep 8
N54 Water Hose Issue
I was changing out my alternator today and came across an issue when pulling off a water hose. The plastic in the end going to the block was rotten. I pulled it out and my car sits in the garage another day. I was wondering if this part was replaceable or if it only comes with the hose and if I can buy it separately what's it called? It's basically the metal piece smack in the middle of 7, 8 and 9 that's got 2 holes for torx can't find a name or part number anywhere [IMG][/IMG]
Mark
05-25-2019, 04:57 AM | #2 |
455
Rep 875
There's aftermarket adapters, I used this one. Cut off the plastic from the hose, just make sure you don't cut too much so the hose can sit properly on the adapter.
https://www.amazon.com/dp/B07DW5C85D..._4dr6Cb9K16CBP |
SEABMW0.00 |
05-26-2019, 06:07 AM | #3 | |
Rep 8
Mark
05-26-2019, 08:45 AM | #4 |
General
17314
Rep 18,737
I just did this swap yesterday and posted a DIY for it in the DIY section.
