Need help with a ABS problem.
05-21-2019, 03:33 PM | #1 |
46
Rep 418
The other day when I went to leave my Break, ABS and DTC lights all turned on. They when off later in the day. It has done this for 3 days in a row. The error codes that came up are 5DF0, 5DF1 adn D35A. Is there a common issure that causes this? I have a 07 338I. I checked the live data on all the wheel speed senors and they all appear to be reading correct when the error lights are on.
Thank you |
05-21-2019, 05:37 PM | #2 | |
2697
Rep 4,031
So what's a fella to do with codes & NO definitions? Fortunately there's "BMW Fault Code Lookup": www.bmwfault.codes Plugging those 3 codes into the "Enter Fault Code" search box yields the following (it would be helpful to know what the SGBD or short code is for you DSC module, but my SWAG is it's either DSC 85 or DSC 87): 5DF0 DSC: Hydraulic unit: pump motor dsc_87 Dynamic stability controlMK60 5DF1 DSC: Hydraulic unit: pump motor connector faulty dsc_87 Dynamic stability controlMK60 D35A No message (CAS 0x304), receiver DSC, transmitter CAS dsc_87 Dynamic stability controlMK60 Those code definitions by themselves suggest to me that you might solve your issue by disconnecting the Connector to the Pump Motor and clean the pins/sockets with Electronic Contact Cleaner, and inspect the wiring, as it appears you have a bad connection. 2007 models had circuit/fuse changes effective 3/1/2007 build date, so check your door jamb for MONTH/YEAR built. The information that follows relates to 3/1/2007 to 8/31/2007 built (late 2007 models). Early 2007 models will have different fuse numbering, and perhaps OTHER differences. Here's the TIS circuit diagram for the Module (A65a), & Connector (X18303): https://www.newtis.info/tisv2/a/en/e...ol-dsc/iDP8oTz Here's the TIS Installation Location for the Module & Connector: https://www.newtis.info/tisv2/a/en/e90-328i-lim/RJPFfg1 Please let us know what you find, George |
05-22-2019, 12:05 AM | #4 | |
2697
Rep 4,031
https://www.newtis.info/tisv2/a/en/e...i-lim/CTMTTUFx https://www.newtis.info/tisv2/a/en/e...ol-dsc/ZFCLhIu Please let us know what you find, George |
05-22-2019, 07:20 AM | #5 |
46
Rep 418
I used Carly for BMW and a Autel scanner and got the same codes on both.
I'm not sure what the SGBD or short code is for my DSC module. How do I find that? My cars build date is 10/07. That is the connector that I disconnected. It is connected directly to the pump. The lights did not come back on today, yet. Thanks |
05-30-2019, 09:51 AM | #7 | ||
2697
Rep 4,031
The SGBD is the code for the DSC and its programming, such as DSC_87 that is found in the "Information" screen using INPA. I don't know whether Carly or Autel is able to view that Information, but its in Module memory. It is helpful to have that, as the Definition of a particular code can vary in some instances depending upon SGBD. BTW, a 10/2007 (October, 2007) build date would be a 2008 model AFAIK. Can you confirm the correct build date per the door sticker? Thanks, George |
05-31-2019, 07:28 AM | #9 |
46
Rep 418
I will have to get you the codes when it happens again. It went off later in the day and I cleared the codes. The door sticker say 10/07.
What usually goes bad on the pumps? Thank you |
06-01-2019, 07:42 AM | #10 | |
Rep 83
The internal brake pressure sensors can also fail but you do not have that problem. Next time it happens you could try a sharp tap to the motor with a small hammer, this may give a temporary fix but ultimately it is on its way out. |
06-17-2019, 04:12 PM | #14 |
dances with roads
4732
Rep 4,096
Get your DSC module refurbished or replaced. I had two of them go south on my two BMWs at the same time (I know right?) and used Module Masters for one of them and a used unit for the other. Both my cars are 2007 with similar mileage, low 80K's.
06-19-2019, 01:33 PM | #15 |
Rep 4
ABS pump part interchangeable years (2008 - ??)
I have a 2008 e93 convertible with only 58k, and the motor on the ABS is shot. How interchangeable are the hydraulic blocs? Can I get a bloc with a motor from a 2011 to match up to my DSC electronic front part? Are the cylinders inside the bloc the same from year to year?
I've looked at real OEM and it's not much help. The blocks all look the same for the 328 series. Any advice would be helpful. Thanks! Marty from Muggy S. Florida Last edited by marty99; 06-19-2019 at 02:10 PM.. |
06-21-2019, 10:02 AM | #17 |
dances with roads
4732
Rep 4,096
I sent the whole works off to Module Masters. There are videos of folks fixing them on their own, replacing the motor or brushes I think.
06-21-2019, 02:36 PM | #18 |
42
Rep 403
Drives: 2007 BMW 328i
The sad thing is I have a 2007 BMW 328i (I am the original owner as I bought it brand new) and I only have 36K km not miles on the car and my bloody ABS pump motor is shot. It started out with all the symptoms you mentioned. Now the ABS light is on all the time. As you can tell I don't drive the car much (only in the summer on weekends) but eventually I will get it rebuilt at Module Masters .
It does piss me off that with so little kms on the car the ABS pump motor went. I believe it's a defect of them using carbon bushings that foul up the pump |
06-21-2019, 02:53 PM | #19 |
46
Rep 418
That stinks. I will have to try to rebuild it my self or replace it. I can't send it off because I don't have a spare car to use. Hopefully I can find some info on rebuilding it.
06-21-2019, 04:32 PM | #20 | |
dances with roads
4732
Rep 4,096
06-21-2019, 04:40 PM | #21 |
80
Rep 354
From what I've been reading, the aluminum block (and attached pump) do separate from the control module (black rectangular piece.
06-24-2019, 08:33 PM | #22 |
Rep 4
I have 3 vehicles, a 2011 BMW e90 with 92,000 miles, a 2008 BMW e93 hard top convertible with 58,000 miles, and a 2005 Lexus RX330 with 104,000 miles. In the past 4 years, the Lexus has cost me $200 to repair a single issue. Everything works with zero defects; all the lights, ice cold AC, factory nav, power windows and locks, bluetooth, HID's, ABS, DSC, power hatch, and all the hundreds of little things. No issues year after year. Both the BMW's fail constantly. I would not take either on a 2 hour road trip. The 15 year old Lexus I would drive to Australia if I could (I live in Florida). I think I'm about done with the German ultimate driving machine. Need something I can rely on. The beemers look great, nothing more. Just my sad 2 cents!
