BMW 5-Series (G30) Forum Wheels | Tires | Suspension | Brakes | Chassis 245/35R20 with 285/30R20 ?
      05-21-2019, 01:32 PM   #1
RDTeam
RDTeam's Avatar
Drives: 5er G30 2018
Hi!
Just interested. Why stock tyre size 245/35 pairs with 275/30? In that case diameter and sidewall of front tires is bigger than rears.
But if we compare 245/35 with 285/30 in tyre calc we will see that this size is more closer to each other. Why so?)
I was using 245/40R20 with 275/35R20 on 7er F01. And bigger sidewall of front wheels are always annoying me. I dont want to repeat that story on my G30 so i'm thinking to use 245/35 pair with 285/30 to make same look for front and rear wheels. Any opinions?
Thanks
      05-21-2019, 03:17 PM   #2
CLABRO
THUNDER UP!
CLABRO's Avatar
263
Drives: BMW M Sport G30
It depends which wheel you're talking about and how wide it is.
You can only run so wide of a tire based upon how wide your wheel is. So BMW probably didn't go with the 285/30/20 because the width of that is over 11" (11.2" to be exact) whereas the 275/30/20 is only 10.8" wide. Unless your wheels are over 9" wide then I'd stick with the 275s, IMO.
For example: My BMW M Sport 664M wheels are 19x9 (9" wide) and the widest tire you'd ideally want to run is a 275. You could probably fit a 285 but it wouldn't look and fit as good as the 275.
Hopefully that makes sense and helps you out.
G30 l Alpine White l M Sport Package l Executive Tier l Icon Adaptive Full LED Headlights l Mocha Nappa Leather l Multi-Contour Seats l Drivers Assistance Package l Drivers Assistance Plus Package l Dynamic Handling Package l Parking Assistance Package l Bowers & Wilkins Diamond Surround Sound System l M Sport Brakes l Apple Carplay
      05-21-2019, 06:12 PM   #3
Superjackson
122
Drives: M550i
I am actually planning to try square 275s 👌even cooler!
      05-21-2019, 11:17 PM   #4
aadum
aadum's Avatar
Croatia
80
Drives: 330xd e92 ,520d f10, 540i G30
what are the sizes of your front rims?
5post
