Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > MHD link- Bad HPFP?
      05-20-2019, 06:21 PM   #1
erzenble
Drives: 2011 335xi m sport PE
MHD link- Bad HPFP?
Run on my 2011 335i just flashed to MHD stage 1 91 octane. now my fuel pressure is really fluctuating and car goes lean when it does. lots of timing corrections where the psi drops. This is proof my HPFP is toast right? Or could my LPFP be the problem? Thanks guys.
https://datazap.me/u/erzenble/2011-3...38&tmax=100.70
      05-20-2019, 06:58 PM   #2
IllSic_Design
IllSic_Design's Avatar
2124
Drives: 09 E92 335i
Your pressure at the rail looks fine, never drops below 2000psi. You need to log your lpfp sensor to see the low pressure fuel pump but it should be fine since your rail pressure isn't dropping low.
      05-20-2019, 06:59 PM   #3
dlipham
Drives: 328i 2010
test
      05-20-2019, 07:13 PM   #4
erzenble
[QUOTE=IllSic_Design;24810060]Your pressure at the rail looks fine, never drops below 2000psi. You need to log your lpfp sensor to see the low pressure fuel pump but it should be fine since your rail pressure isn't dropping low.[/QUOTE=
hmm the psi drops from 3300 psi down to 2500 psi and back a few times, each time it does that my AFR goes lean and right at the same time i was getting timing corrections in most cylinders up to -6. Is a 1000 psi drop not a problem?
I was also getting corrections with stock MAP.
      05-20-2019, 11:38 PM   #5
erzenble
Anyone know how to log LPFP on MHD? I dont see the option anywhere.
      05-20-2019, 11:57 PM   #6
IllSic_Design
2124
Drives: 09 E92 335i
oh you have N55, I don't think you have a lpfp sensor if I remember correctly.
      05-21-2019, 08:33 AM   #7
RomKaN54
Ukraine
23
Drives: 2009 335i 6MT
not expert but your boost is always under 10psi? even when boost targets requesting 14psi....
      05-21-2019, 08:50 AM   #8
JUMAS
39
Drives: 2011 335i
you're correct
      05-21-2019, 08:59 AM   #9
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
2659
Drives: 11' 335is DCT
Wow I'm baffled how their car don't have a LPFP? Why lol.
      05-21-2019, 11:52 AM   #10
erzenble
yes exactly, im not making target boost either. I think the DME is limiting my boost since i have other problems.
      05-21-2019, 11:59 AM   #11
erzenble
anyone mind throwing in there HPFP logs for a comparison? from what i read the pressure is supposed to be pretty steady with no sudden drops because if its not steady it will change the amount of fuel thats supposed to be injected and mess up AFR's.
Was hoping someone could confirm or tell me im wrong before i spend 500 dollars on a pump. There not cheap unfortunately.
      05-21-2019, 02:20 PM   #12
IllSic_Design
2124
Drives: 09 E92 335i
post in here, you will get more help https://www.e90post.com/forums/showt...hlight=mhd+log
      05-21-2019, 02:37 PM   #13
erzenble
Will do thanks.
      05-21-2019, 02:54 PM   #14
Pladi
Pladi's Avatar
718
Drives: 2011 335i xdrive
This has been discussed alot on mhd forum. Its related to the newer maps when pressure goes above 2800 psi.
If u flash to stock u wont see this issue.
      02-05-2024, 03:53 PM   #15
ilikemycar
Drives: 2011 E90 335i
Hey man. Same issue here, how did you fix it? My graph looks same.
Thanks for info.
      02-06-2024, 11:00 AM   #16
Cloverdale
123
Drives: 2007 335i Jb4 & perf. mods.
Which parameter from your log indicates 'fuel pressure is really fluctuating' ? Is there a fuel pressure parameter in your log other than 'rail pressure mean psi'? My JB4 logs provide hpfp and lpfp numbers but I don't see that your MHD log has any comparison parameters.
Tags
335i, logs, mhd
