06 325i-Timing Cover Oil Leak
05-20-2019, 04:07 PM | #1 |
108
Rep 148
I was looking at purchasing a used 06 325i from car dealership (non bmw) that the dealership must of taken in on a trade. Their internal inspection report showed oil leak from Oil Pan 9.9, Timing Cover 9.5 and Valve Cover 4.5.
What is the timing cover that is leaking oil? I assume their numbers after each item are book time. If you are already replacing the valve cover gasket, how much more difficult is it to replace a timing cover gasket (if there is one). Last edited by Explorerlyon; 05-20-2019 at 04:58 PM.. |
05-20-2019, 04:31 PM | #2 | |
Robot
1685
Rep 2,190
If the oil pan gasket and valve cover gasket are leaking, it's likely that the oil filter housing gasket is leaking too. This requires less time to replace than a valve cover gasket, so maybe that's what they're calling the "Valve Cover" and the "Timing Cover" with 9.5 is what we all commonly call the valve cover. There's no labor savings when doing them together; you can replace either one without touching the other. There's also the valvetronic motor gasket, which is attached to the valve cover. That's best replaced at the same time as replacing the valve cover gasket, since you have to remove the valvetronic motor (and gasket) to remove the valve cover. However I wouldn't be getting any repairs done by someone claiming 10 hours for an oil pan gasket repair or 9.5 hours for a valve cover gasket repair. I replaced my valve cover gasket in about 6 hours and I *really* took my time, mostly just learning since I was unfamiliar with the N52 at the time. Edit: I don't know how familiar you are with these cars, but those leaks shouldn't turn you away from the car. These are all common leaks and everyone here has had to deal with them. Last edited by lowrydr310; 05-20-2019 at 04:38 PM.. |
05-20-2019, 04:45 PM | #3 | |
108
Rep 148
05-20-2019, 05:13 PM | #4 |
3973
Rep 7,215
Unless the oil pan is leaking like a BP oil rig, just leave it alone. It's not worth paying somebody $2000 to fix it when it might lose a quart in 10,000 miles.
the other leak sounds like either the OFH, valve cover, or possibly the two bolts in the timing cover area on the inside of the engine have broken and need replaced. you could do that while you do the VCG. |
05-20-2019, 06:11 PM | #5 |
398
Rep 1,579
There are a 4 head bolts that go into the timing chain cover area. Usually only the outer exposed one breaks (figure #1 in 1st link). See links below for more info.
https://www.pelicanparts.com/BMW/tec...lt_Testing.htm https://www.bimmerfest.com/forums/sh...d.php?t=958844 |
05-20-2019, 06:22 PM | #6 |
3973
Rep 7,215
Calling them 'head bolts' is misleading (although technically correct), since they don't actually seal the combustion chambers or coolant passages around the cylinders. It's just that on an N5x, BMW integrated the timing cover with the head and block, ironically because it reduces the chances of a leak..
05-20-2019, 07:25 PM | #7 | |
398
Rep 1,579
hassmaschine3972.50 |
05-20-2019, 09:10 PM | #8 |
General
17314
Rep 18,737
Is the car 2-door or 4-door?
05-20-2019, 09:18 PM | #9 |
3973
Rep 7,215
pretty sure all 06's are 4 doors.
also, if the gasket is leaking because the bolts are broken - you can just replace the bolts, and it should stop the leak. |
05-21-2019, 05:05 AM | #10 |
General
17314
Rep 18,737
The 2006 325Ci (2-door coupe) was an E46 with an M54, which has a timing case. I was just trying to verify if the OP has an E90 or an E46. If it is an E46, then it could have a leak at the timing case. The E92 2-door coupe didn't come out until 2007.
05-21-2019, 01:09 PM | #12 |
General
17314
Rep 18,737
05-22-2019, 06:18 AM | #13 |
398
Rep 1,579
If the bolt in Figure 1 above is broken, is an easy fix. Loosen the intake manifold bolts, pull the front of the manifold back an inch or so, spin out the broken bolt (it should come out easily with a pick) and replace bolt. There is no need to unhook the intake wiring or tubes.
When the bolt breaks, pressurized oil comes up from the threads and leaks down the side of the head. It is common for this bolt to break on 2006 N52. |
