600 whp 328i on N52???
05-17-2019, 02:44 PM | #1 |
97
Rep 239
I just came across this dyno vid of someone making 596whp on n52.. with 19psi boost
I couldnt find a build thread here, im definitely curious what it took to achieve this because this is insane if its legit. |
05-17-2019, 05:00 PM | #2 |
433
Rep 600
Drives: TiAg e91, r53 Cooper S, e28 M5
Hmmmm, I like the idea of that, I really want to know if this is legit. I would have guessed the block to be a weak point at this power.
05-17-2019, 06:06 PM | #3 |
2188
Rep 5,002
Is that guy in Florida? i think he posted on here. Weak point generally the rods and pistons as BPC found out with their turbo N52. Held a lot more than I would have thought. 500+whp for quite some time.
05-17-2019, 06:51 PM | #4 | |
97
Rep 239
If you ask a n54 guy a n52 cant handle 1 hp extra without it collapsing into the Nth dimension |
05-17-2019, 06:53 PM | #5 |
97
Rep 239
05-17-2019, 07:30 PM | #7 |
551
Rep 2,293
yes its true. Digidon is the user name . This is on stock engine as far as I can remember, He has n54 transmission swap
There isnt really a weak point on the N52 , he has been running over 400 whp for a long time. That was a one time ran He pointed out the weak point was the n52 transmission 350 whp was the max , BPC also confirmed this . But engine wise he found the N52 block can handle that type of power BPC actually has/had a turbo kit available , the only downside was that the air conditioning unit had to be removed , so this kit was " available" if someone really wanted to buy it . Digidon's turbo set up keeps the air conditioning unit , but his kit is not for sale , he owns a shop and he does all the work on his car .... |
NFiftyWon97.00 |
05-17-2019, 08:25 PM | #8 |
3764
Rep 2,738
I seem to recall that digidon eventually blew that motor. Here is his thread in case anyone is interested...
https://www.e90post.com/forums/showthread.php?t=1325782
NFiftyWon97.00 dakine_surf432.50 |
05-19-2019, 08:30 AM | #9 |
Hoonigan
6849
Rep 3,000
Drives: '09 328i, '98 Wrangler
I love the N52, but I don't understand why people turbo them. You can find an N54 car for not that much more that already has a turbo out of the box and stronger internals. Building an N54 to make that power would be cheaper and much more reliable than some pieced together kit for an N52.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
05-20-2019, 02:41 PM | #10 | |
97
Rep 239
05-20-2019, 03:07 PM | #11 | ||
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
The S65 is 5x as expensive(or more) to get to 650whp. Also no one has made over 700whp iirc even with built motors. So if you are chasing numbers/records for E9X etc. the S65 is not the engine of choice. You can make 650whp on an N54 for like 6k using all off the shelf parts and tuning etc. You can get a DCT N54. Never going to make 1000whp on an S65, N54 can make that. The N52 is a good motor just keep it as is and let it be good at what it does well.
b92539.50 |
