rattle at idle
05-17-2019, 11:18 AM | #1 |
Rep 27
rattle at idle
Hello, I am new to the N54 but not BMW, my car recently started making a rattle that I could hear at idle when the A/C is on. Sounds like a loose heat shield and when under the hood sounds more like it is coming from underneath the airbox or oil filter housing than from the front of the car belt, tensioner, pulley, etc.. It doesn't make the noise until the car is warm (viscosity issue somewhere?) and also immediately goes away if you increase RPM. I am going to do an oil change this weekend and may pull the whole belly just to have a look when I do the oil change. Any thoughts would be greatly appreciated.. I did put my stethoscope on the tensionser pulley and 2 others that I can easily get to and don't hear anything abnormal on them, of course it could be a pulley that I can't get to.. I am happy to try and post the video somewhere if it will help.
Thank you in advance for any ideas. |
05-17-2019, 11:45 AM | #3 |
5483
Rep 5,422
Drives: Beige G31 40ix m sport
How many miles has it done?
I would say that the most likely candidates are waste gate rattle, that comes from drivers side low down by the front wheel, could be injector tick which is normal. It will rattle from the exhaust flap, this is closed on start up which rattles & it opens once the cars been running a for a couple of minutes or so, then the rattle stops but that comes from the passenger side at the back. I would say it's most likely gonna be the waste gates rattling. Welcome to 35i ownership
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle Last edited by Chappers 71; 05-17-2019 at 11:54 AM.. |
05-17-2019, 11:57 AM | #4 |
Rep 27
the noise is high not low, what about the disa valve? anyone dealt with one? car has 115k on it. I have done the rev test for Wastegates, doesn't seem to have any noise on the rev test.
Last edited by portlandareae28; 05-17-2019 at 12:01 PM.. Reason: better description |
05-17-2019, 12:29 PM | #5 |
5483
Rep 5,422
At that mileage if the turbos haven't been replaced they will have waste gate rattle.
I've never read of anyone posting about disa valve issues on a n54.
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
05-17-2019, 12:46 PM | #6 |
Rep 27
hmmmmm... where it sounds to me like the noise is isolated is between the air box, oil filter housing, and valve cover. It sounds like a rattle and less like it is rotating but I am no expert by any means. I don't know that the rattle is the valve it self or maybe the pieces that the valve controls. I am going to listen closer again tonight, I don't and won't drive the car until this is solved. Ultimately I just don't want to throw parts at it, its not a car that I need to drive everyday so I want to take my time, isolate, learn and fix.
05-17-2019, 12:50 PM | #7 |
1903
Rep 6,968
05-17-2019, 12:58 PM | #8 |
5483
Rep 5,422
G31 40ix M Sport
05-17-2019, 01:10 PM | #9 |
Rep 27
well good, that is not my problem than :-) :-) :-)
I will check for heat shield rattles this weekend, but the fact that cold it doesn't do it and warm it does, and the a/c plays a role too gets my brain thinking something more complicated than a heat shield rattling. My wife says she feels it in the floor of the drivers compartment so maybe it is lower than it sounds.. |
05-17-2019, 02:22 PM | #10 |
Rep 27
05-17-2019, 02:24 PM | #11 |
Rep 27
Will the waste gates just rattle at idle and go away with higher rpm even with no load? Would the A/C being turned on and or off have an effect on this?
05-17-2019, 03:36 PM | #15 | |
1903
Rep 6,968
05-17-2019, 03:39 PM | #16 |
Rep 27
05-17-2019, 06:28 PM | #17 |
5483
Rep 5,422
There's the usual injector tick but that other noise sounds like a rumbling bearing, possibly alternator?
The noise in the vids doesn't sound like wg rattle, that would be more of tinkling kinda noise when you first start the car
G31 40ix M Sport
05-17-2019, 08:36 PM | #18 |
52
Rep 250
Almost sounds like hallow plastic vibrating against something.
My other car (not a BMW) had a similar sound, it was a blower motor that needed to be replaced. |
05-17-2019, 09:28 PM | #19 |
Rep 27
05-18-2019, 04:49 PM | #20 |
Rep 3
I've sort of the same problem. Cant post yet.
2007 328Xi A couple of days ago I was changing parking spaces and the engine cut off on me. Idling hard. Turned out to be misfiring on 1 3 and 4. Changed all the plugs and coils. Eccentric Shaft? was changed a few thousand miles ago. also had a N1415 code. But its still idles rough a little at start, jumping between 12 and 4 RPMS 1 or two times.. then settling around 5 after a couple minutes. |
06-17-2019, 06:21 PM | #22 |
Rep 27
pulled the belly pan off this weekend, found some oil of course and 2 bolts missing from the power steering pump. Amazing the belt hasn't shredded already. Luckily I don't drive it much normally, and since the noise I haven't been driving it at all.. I am not sure I have figured out the best path to the rear bolt yet, but I will be doing the filter housing at the same time. I am so far understanding the intake manifold has to be at least moved to do the filter housing. Since I don't know how long the filter housing has been leaking, will likely want to pull the alternator and clean that whole area. Please offer any wisdom on making the job easier, and keeping the ps pump bolts in place long term?
