05-16-2019, 12:26 PM | #1 |
46
Rep 194
AC always on at startup
When I start my car the AC is always on and I have to shut if off. How do I set it so the AC is not on at startup...the way a normal car works. Sorry if this is a dumb question.
05-16-2019, 01:03 PM | #2 |
247
Rep 776
General consensus here is to leave the ac on for the health of the system.
Lance_Goodthrust4.50 |
05-16-2019, 01:32 PM | #3 |
88
Rep 279
theres a code
IHKA 3002 MEMORY_OFF aktiv nicht_aktiv Air Conditioning will remember if ‘Off’ or ‘On’ from previous shutdown. i did it on my with bimmercode expert mode |
05-16-2019, 02:35 PM | #4 |
731
Rep 1,045
Don't need to be in expert mode, the OP has HVAC in AUTO mode, and his car is setup for A/C to always run in auto mode as seen in the picture I attached.
Mods: Dinan Tuned, Intake, Catless DP
05-16-2019, 02:45 PM | #6 |
731
Rep 1,045
Yes, something else does trigger the A/C to turn on, I can't remember what it was, it happen on my E92 years ago. Was it defrost ? Can't remember, but now since I coded everything, it never turns on unless I press the A/C button.
05-16-2019, 05:59 PM | #7 | |
46
Rep 194
So how do I get it to not turn on when I turn on the car? Is this something as simple as going into the idrive? |
05-16-2019, 06:16 PM | #8 |
576
Rep 584
05-17-2019, 05:46 AM | #9 | |
88
Rep 279
ill check my settings and see how its configured |
05-17-2019, 11:09 AM | #10 |
133
Rep 433
My standard solution is to take my already-enabled finger and push the "lower the fan speed" button until the A/C is off. No coding required.
The Real Heat has arrived, however, and I am starting to leave it on because I will need it in a very few seconds. |
