Stock turbos too much boost?
05-14-2019, 10:51 AM | #1 |
V8 Bait
206
Rep 769
I have MHD stage 2+ 93 oct and no other tune. My car regularly hits 21.5-22 psi max boost at WOT. is anyone else experiencing this? I have inlets, CP-E charge pipe, and 7" HPF FMIC. The car runs great im just concerned about such high boost. My A/F is mid 12's.
Broke AF
05-14-2019, 11:00 AM | #2 |
98
Rep 300
I would only hit 15 lbs on 2+. Even e60 only bumped me up to 18. I had to get a custom tune and 3.5bar map sensor to run 22psi. Something doesn't sound right, maybe your bov spring is too heavy, wastegates aren't working correctly or the sensor is not calibrated correctly.
"Wheels and exhaust aren't a build"
05-14-2019, 11:16 AM | #3 |
V8 Bait
206
Rep 769
I don't believe my bov spring is too heavy. its open at highway speeds. and never has a problem discharging. I know my waste gates are tired but the problem might lie in that i have removed the canisters and im hitting high boost before the waste gates can react. Theres not really any problems happening and im not getting overboost codes. Its just weird.
Broke AF
05-14-2019, 12:36 PM | #7 |
2657
Rep 6,290
05-14-2019, 12:56 PM | #8 |
46
Rep 117
Sounds about right with inlets. Im running JB4 with BEF 94 oct with out inlets and hitting 19 psi consistently. I do also have few other bolt ons FMIC, High Flow Cats, XHP stage 3, Turbo Smart DV,s, BMW PE.
Antetokounmpo1551.50 |
05-14-2019, 01:17 PM | #9 | |
2657
Rep 6,290
Edit: Didn't notice BEF as well. |
05-14-2019, 04:15 PM | #10 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
inlets would cause the turbos to produce more boost provided same wgdc
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
05-15-2019, 08:36 AM | #11 | |
175
Rep 595
05-15-2019, 08:37 AM | #12 | |
641
Rep 1,245
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
Bimmer_Engineer1043.50 The_E92_Fan206.00 |
