Rear headlight level sensor 2007 335i
05-12-2019, 09:25 PM | #1 |
Rep 2
Hello, I am currently in the process of putting the rear suspension back together after installing a set of kw v2 coilovers. The issue I'm having is actually how to reposition the rear headlight leveling sensor. When I dropped the LCA I didn't see how it's supposed to sit and now I cannot find an actual picture of the assembly in position anywhere. Any clear pictures or references are greatly appreciated. I will include a picture of mine hung up at the moment for reference.
01-17-2021, 08:40 PM | #4 |
99
Rep 840
01-17-2021, 08:49 PM | #5 |
Neo-Luddite
2614
Rep 1,401
Drives: '06 325i, 330i 6MT RWD Sport
Glad you got it sorted out. Mine is apart ATM but I took some pics, leaving them for others.
01-17-2021, 08:55 PM | #6 |
99
Rep 840
3PedalJake2613.50 |
01-17-2021, 09:11 PM | #7 |
Neo-Luddite
2614
Rep 1,401
No, that pic was after I started removing things. I snapped some new ones to make it clearer. The bracket that the sensor is attached to is mounted by a clip nut into a square hole near the lower control arm bushing on the subframe, the little bent locking tab goes in a hole next to it. The mount for the other end of the arm goes on the control arm as in pic 1 on first my post.Hopefully the pics will make it clear.
dleccord98.50 |
01-17-2021, 09:51 PM | #8 |
99
Rep 840
thanks boss. will make another trip to the garage in the morning but your photos helps tremendous and will help others in the future.
are you also installing coilovers? this is where i'm at with installing my TC Klines SA's: |
3PedalJake2613.50 |
01-17-2021, 09:59 PM | #9 |
Neo-Luddite
2614
Rep 1,401
Glad I could help.
Nice, I'm sure it's gonna be a huge step up. I have a 330i, I thought coilovers would maybe be over the top for my powerband but I installed Bilstein B8s and Eibach sport springs today along with M3 arms and stuff. https://www.e90post.com/forums/showp...ostcount=14707 |
01-19-2021, 12:56 PM | #10 |
Neo-Luddite
2614
Rep 1,401
How did you make out? I got mine back in what I believe is correct.
