Transmission Slipping
05-09-2019, 03:40 PM | #1 |
63
Rep 268
The car: 06 325i
Took it to the mechanic today, was in limp mode and they said it was because it slipped between 5th and 6th Wants $1200 to fix it , Fix what??
‘06 325i
05-09-2019, 04:59 PM | #3 |
38
Rep 105
Hey im having trans problems too. I have the 5088 code. Did your mechanic pull your code?
My sensor is telling my computer that my trans is in another gear so it doesn't let the car start. I'm working on mines right now and will try to help as much as i can. 5088 sensor gearbox selector switch. Good luck with your car |
05-09-2019, 06:55 PM | #4 | |
63
Rep 268
That's ridiculous. This is the first time it's ever happened
Good luck to you as well
‘06 325i
05-10-2019, 02:25 PM | #5 |
1082
Rep 1,676
Hawaiian's 335 is probably a ZF transmission. OP's 325i might be GM?
I think the mechanic might be stuffing a junk yard transmission in there for $1200. Try a transmission specialist. |
05-10-2019, 02:34 PM | #7 | |
63
Rep 268
I'm leaving it alone, at least for now
‘06 325i
05-10-2019, 02:39 PM | #8 | |
2657
Rep 6,290
I would be curious to know what he'd say tbh |
05-10-2019, 02:42 PM | #9 | ||
63
Rep 268
I don't remember exactly what it was as I eventually tuned out. Probably will be doing more research later on if it becomes more common
‘06 325i
05-10-2019, 02:42 PM | #10 |
1082
Rep 1,676
You can change out the transmission fluid and filter and see how that helps. Is yours a GM or ZF transmission?
05-10-2019, 02:50 PM | #11 | |
63
Rep 268
That would make mine zf I plan to do the fluid and filter soon
‘06 325i
05-10-2019, 10:44 PM | #13 |
Rep 7
I have a e91with 199k miles and it has gone into limp mode once or twice -- but it seems to be ok after pulling over and shutting off the car and restarting -- BMW quoted me a butt load to replace the transmission -- and another told me it was probably just a dirty sensor and to just keep a eye on it -- Honestly in my case its been driving fine ever since -- good luck!
-- forgot to mention the error was in the same gears 5 & 6 |
05-11-2019, 05:21 AM | #14 | |
63
Rep 268
I'll probably drive just being aware that it did happen
‘06 325i
