04-10-2019, 05:04 AM | #1 |
220
Rep 541
Issue coding M Performance brakes
So I have done a bit of FDL coding before and also VO coded EBT successfully
I am using Esys 3.27.1 and Launcher 2.8.0 I overcame the token timeclock issue by downloading a script (although as I understand it this only prevents FDL coding). I am following this instruction to VO code m performance brakes - 1. Connect=>Expert Mode=>Coding=>Read FA=>Save FA 2. Editiors & Viewers=>FA-Editor=>Go to HO-Wort and right click to "Edit", then type (means add) "SPBR" under HO-Wort folder 3. Highlight the FA, "Activate FA" and "Calculate FA" to verify no error is found after adding the SPBR. 4. Check the Vehicle Profile to locate the "aftermarket retrofit" and verify the "SPBR_18_ZOLL_SPORTBRAKE" is added to the folder 5. Write FA to the car. No confirmation window will pop up after saving the FA to the car. So you need to go to next step for verification. 6. Expert Mode=>Coding=>Read FA. You are able to see the SPBR being added to the HO-Wort folder on your car. 7. Read SVT, and locate the "DSC" (File Folder SVT/ECU/DSC), then right click the "DSC" folder and select "Code". Coding would begin immediately. 8. Wait until the coding is finished, and repeat Step 1 to save a copy of the new FA. After coding the DSC folder in step 7, I get the green text to indicate its been successful. Then when I read the FA again to check SPBR is in there its not. Is this the reason...... In step 2, EDIT is greyed out for me (pic below) when I choose NEW, I can then add SPBR Also I cannot see any text in my vehicle profile. I checked another post and AFTERMARKET is number 8 and SPORTBRAKE should be the file 1957, which is there. What I am doing wrong? |
