Topping up engine coolant
04-06-2019, 12:31 PM | #2 |
5510
Rep 5,433
Drives: Beige G31 40ix m sport
50/50 mix with de ionised water is what's recommend
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
04-06-2019, 03:35 PM | #3 |
1073
Rep 1,959
Drives: E90 M3 LCI Jerez Black
You can use tap water according to a BMW dealer i spoke to in Germany. He looked at me funny when i asked if i need to use any water in particular. “Regular tap water is ok” in his best German English accent.
04-06-2019, 04:20 PM | #4 | |
5510
Rep 5,433
I just use de-ionised as British tap water has a lot of additives in it, I do use tap water in the Navara though.
G31 40ix M Sport
04-07-2019, 11:23 AM | #6 |
106
Rep 576
Depends whereabouts you live.
In soft water areas it may be ok but in London and where I live now the tap water is full of chalk and chlorine. Take a look at your kettle. If it furrs up with limescale in a week would you want that inside your Beemer motor? I don't think you need de-ionised water though. Distilled will be fine or the water that normally gets tipped away from an air-con unit is good. |
04-08-2019, 12:11 PM | #8 |
18
Rep 137
Thanks guys.
I might not even need to top up now, the warning light went away after I restarted the car. I checked the level aswell and it's on max. But there is another coolant container on the right hand side which doesn't have a measurement gauge?! |
04-09-2019, 12:22 AM | #9 |
243
Rep 2,026
you mean the screen wash bottle?
04-11-2019, 12:30 AM | #13 |
243
Rep 2,026
04-11-2019, 03:17 AM | #14 |
106
Rep 576
04-16-2019, 03:20 AM | #16 |
12
Rep 56
The secondary coolant tank is for the chargecooler on your car, all E90/1/2/3 use intercoolers so you might be in the wrong section...
Anyhow both reservoirs on your car take the same coolant, and both can produce low coolant alarms. Last edited by lloydie; 04-16-2019 at 03:29 AM.. |
