Front windshield washer problem
04-06-2019, 07:39 AM | #1 |
Rep 4
Hello guys,
Yesterday the front washer stopped working out of the blue. I'm going to list everything for convenience: - rear washer works fine - when I pull the stock to wash there is no sound and the wipers don't move at all - wipers work normally when I move the stock up (or on auto) -all the fuses are good |
04-06-2019, 07:55 AM | #2 |
151
Rep 460
Could be the washer motor. I had to replace ours on our 2007 335i. I seem to remember it was behind the passnger side front wheel well. They are only a few dollars for aftermarket.
04-06-2019, 09:03 AM | #3 | |
Rep 4
Where the wipers working in your case despite no water coming out? |
04-06-2019, 12:34 PM | #4 |
2442
Rep 4,330
wipers not moving indicates that it's not a washr pump issue.
if the pump were dead you'd get wipers, just no fluid. I would suspect the switch in the stalk itself. You'll need inpa/ista so you can check the status os the switch as the electronics see it. or you'll have to get at the harness and test it with a meter for continuity. newtis will have the wiring diagrams. |
jayhawkc15.00 |
04-06-2019, 03:47 PM | #5 |
Rep 34
I just had the same symptoms with my 2007 328i coupe. No fluid, no sound from washer motor, and the wipers didn’t move. I replaced the washer pump and everything works again.
BTW, I was able to replace the pump without jacking up the car and removing the wheel. Grimes |
jayhawkc15.00 |
04-06-2019, 04:11 PM | #6 |
15
Rep 25
I have this problem as well. I wonder if they have a failsafe built in so if the washer pump isn't squirting, the wipers won't activate to make the situation worse safety-wise.
I'm going to try replacing the pump and see what happens. Good info. |
04-06-2019, 04:45 PM | #7 |
Rep 34
Tags |
e91, problem, wipers |
