03-24-2019, 05:12 PM | #1 |
139
Rep 467
Re-gapping plugs for MP flash
Can someone tell me why it is that we're recommended to re-gap plugs to 0.022 on the Alex's MP flash? I went ahead and replaced the plugs with OE plugs. 21k plugs on the originals and they still looked fine. I've noticed a cleaner pull but I'm feeling sort of less violent WOT hit. I've also noticed the car heat soaking "easier" than with the previous OE gap. Any insight? Thanks folks!
Eric |
03-25-2019, 09:10 PM | #2 |
810
Rep 1,455
As you turn up the boost and run richer fuel mixtures, you want a more intense spark, which is achieved by closing the gap slightly. It's probably a safe "recommendation" but you're probably fine on stock plugs. May just need to replace them sooner. Ours are already 1-step colder than N55/N54.
eksigned139.00 |
03-25-2019, 09:38 PM | #3 | |
139
Rep 467
03-25-2019, 10:34 PM | #4 |
809
Rep 1,371
Yeah, OEM plugs should be fine, but they do tend to need replacing sooner with a tune. I started to get stumbling around 27k (JB4 installed at 1200 miles). I went with OEM plugs at stock gap (.027 IIRC) and it cleaned the stumbling right up. And G-Newt is correct; our stock plugs are already one step colder than N54/55. A lot of people seem to think the NGK 97506 is two steps colder than our stock plugs, but in reality it's only one step colder.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
G.Newt810.00 |
