03-23-2019, 07:56 AM | #1 |
2267
Rep 3,281
Fuses - switched vs constant power Solved!
Hello All.
F90 front fuse box. Located lateral front passenger side under the removable panel below glove box. Front most row of large fuses F20 to F29 are switched off (about a 10 minute time out). Rear most row of large fuses F48 to F59 are constant. Slot 23 and Slot 49 are not used so perfect for a Fuse Tap connection. The "Hot" side of the fuses is the outside (lateral side) so you need to orient your fuse tap properly. Fuse Tap requires BOTH fuses be plugged in since the first fuse (the one that ends up closer to the fuse box) provides fused protection for BOTH the circuit you are taping and to the FUSE tap output fuse. I checked it's wire setup with volt meter. More photos on takedown of panels to follow. Photos not great, iPhone, dark garage....cropped. LOL. I'll reshoot with my Canon EOS 1DX with Flash later. (JK, I am not) Mike
2018 M5 and 2019 Porsche Boxster GTS Prior. '94 325is, '97 M3 Lux, '16 M2 |
09-02-2020, 09:21 AM | #3 | |
Peanut Butter Jelly Time
21
Rep 199
You. Are. Awesome. |
10-24-2021, 06:42 PM | #4 |
197
Rep 572
Digging up a slightly old thread. I'm trying to hard-wire my radar detector and cannot get any power from this fuse panel. In my 2018 I just used the mirror tap and it worked fine, but I cannot get the panel off and I'm not going to risk breaking it. So I figured I'd try this fuse panel. Easy to get to, but I just cannot get any power. I've tried my setup in my other vehicle and it works fine so it's not a faulty fuse tap or power cable. I tried both slots mentioned above and nothing. I even pulled one of the existing fuses and tried to piggyback off that. Still nothing.
Any suggestions? Might my fuse tap not be long enough? Again, it worked fine in my wife's car, but it's a MB. This is for a 2022 F90 M5C. |
10-25-2021, 06:46 PM | #5 |
2267
Rep 3,281
One section will be always hot and the other switched off with the ignition, you'll need a volt meter to check. Remember the fuses have two sides, one will be the hot side and the other not. To test for 'off' with the ignition you have to wait about 5 minutes for the circuit to time out. Some cars even longer.
Mike
10-29-2021, 11:12 AM | #6 | |
197
Rep 572
Thanks man. |
10-30-2021, 07:43 AM | #7 | |
2267
Rep 3,281
Mike
02-28-2022, 08:13 AM | #8 | |
Kohan
Rep 24
Hey. Do you happen to have the link of the fuse tap you used? Can't seem to find it anywhere Thanks! |
02-28-2022, 10:21 AM | #9 |
2267
Rep 3,281
Car Vehicle Mini Fuse Holder Cable Adapter with 5AMP Fuse and Negative Ground Wire Circuit Blade Style ATM ATT Low Profit TAP by HitCar - Medium Size
by CZTrader02 Learn more: https://www.amazon.com/dp/B071NWRH9V...ing=UTF8&psc=1
03-01-2022, 07:17 PM | #10 |
Kohan
Rep 24
Hey all.
Need 40Amp power for a PA speaker, anyone know where I can pull power from. Couldn't find any fuse taps that can handle 40a 2019 5 series Any clues would be helpful! Thank You! |
03-02-2022, 11:59 AM | #11 |
2267
Rep 3,281
in front fuse box, second fuse from right is a 40....
Mike
05-18-2022, 07:25 AM | #12 | |
16
Rep 15
Power Up Question
This is excellent and super helpful, thanks! I wired up my detector in my 2022 M5 the same way and it works well, with one odd thing: If I'm in and out of the car during the day, the detector will power up, stay on when I leave the car, and then power down after the delay (10 min or so) consistently. However, when I leave the car overnight, the detector will not power up when I start the car, it requires that I press the power button (on the detector) and then it powers up normally. I'm taking a guess that the car has a "smart" power management system where it supplies less than full power to circuits after "going to sleep" and that it then provides full power when the attached device calls for it? Any thoughts on whether that's possible? Anyone else had this happen? Either way, thanks again.
05-19-2022, 06:38 AM | #13 |
5179
Rep 10,557
The circuit for whatever you tapped into probably wires that way. The car does go to sleep and wake up and there are things you can do to trigger those events before they would otherwise occur as part of the car’s electronic system. I’d probably research that.
05-19-2022, 01:06 PM | #14 |
2267
Rep 3,281
I checked to see, my radar and dash cam go off after about 5 minute. They come on again if you disturb the car in any way, open a door, open the trunk, kick it hard enough.
Too bad the car does not have an At Home mode where it is off completely. I get the 'vehicle recovery' aspect of the always talking to the cloud BS, but the thieves get around that pretty quickly. (disconnect the battery, car is quiet). Mike
05-24-2022, 02:08 PM | #15 | |
Rep 23
05-24-2022, 02:40 PM | #16 |
5179
Rep 10,557
If you lock the car does it stay asleep longer?
Radar is low amp. Honestly I would just use a mirror tap wiring kit. I did. But if you insist on using the fuse box, I would choose a low amp fuse and use a fuse tap. You could go off the passenger side footwell fuse box. I run my meth pump that is in the engine compartment from there. |
