03-20-2019, 03:03 PM | #1 |
24
Rep 45
Creaking in da rear
Hey guys/gals
2016 3040i 20k miles with M Sport Package & Track Handling Package. When I get in/out of the vehicle there's a small creaking noise coming from the rear. I don't hear it over the sound of engine/exhaust. I only notice it while parked with engine off. The local BMW mechanic says he "can't duplicate the problem" I'm guessing it's just some sort of bushing or something that needs a little grease??? Maybe it's something I can lube up myself? Can ya point me in the right direction? Thanks in advance. |
03-20-2019, 03:40 PM | #2 |
248
Rep 2,387
20K miles is very early for bushing/ball joint problems, but I've had the exact same noise (two times) when exiting the car (on my 5er). Both times it was the rear ball joint. It connects the wheel bearing carrier to the swing arm and can't be lubed. I would think this would be covered under your warranty.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
03-20-2019, 04:28 PM | #3 | |
518
Rep 891
Whatever is affecting OP's ride should definitely be covered. Is the noise present regardless of emergency brake engagement?
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
03-21-2019, 01:58 PM | #4 |
24
Rep 45
The mechanic finally reproduced the noise. He said its the parking brake. I always use the parking brake when parked so the weight of the car doesn't rest on the transmission.
I'll do some testing with & without the parking brake. The service advisor said it can't be fixed. I have trouble believing that. |
03-21-2019, 06:53 PM | #5 |
2001
Rep 2,499
Parking brake noise is basically unavoidable. Why does it bother you? I'm used to it since I've always had to use my parking brake on my cars. How can they fix two friction materials rubbing up against each other making noise when the suspension geometry is slightly changed? There's no way.
03-21-2019, 08:12 PM | #6 | |
Rep 36
03-21-2019, 08:34 PM | #7 |
481
Rep 1,572
I had the same issue and discovered it was also the parking brake. In my case, I was not setting it hard enough and just the little play was enough to make the creaking. My solution was to pull up harder on the parking handle which solved it for me.
03-21-2019, 09:50 PM | #8 |
24
Rep 45
I've had quite a few cars in my life including other BMW's (E36 M3 & and E46 M3) and none of them displayed this. Why does it bother me??? Because I work hard for my money & a vehicle of this value shouldn't creek like an antique door.
03-21-2019, 09:53 PM | #9 | |
24
Rep 45
Thank buddy > appreciate the tip! |
04-01-2019, 02:22 PM | #11 |
Rep 2
E-Brake Creaking Fixed!
I had this exact same issue on my 2015 F36 - slight creaking from rear driver's wheel well upon entering/exiting vehicle with e-brake engaged.
I read another post somewhere on this forum (wish I remembered where so I could share credit...) the trick was to go out to a 'safe' area and drive the car at low speed and apply the e-brake to slow down the vehicle (i.e. slow down from 20km/hr -10km/hr). Keep the lock button depressed on the lever so as not to actually engage the mechanism, simply pull gently to allow some friction. You will see a warning pop-up in your cluster, just release the brake by placing it back down and releasing the button before the vehicle actually comes to a stop. After doing this gently three times while driving (once down the driveway and twice more rolling gently to a stop at red lights), the creaking sound was gone when I parked and got out - immediate fix. |
thegr8wendt23.50 |
04-01-2019, 04:45 PM | #12 |
24
Rep 45
I'll give it a try, Thanks Battle Axe!
11-28-2021, 05:36 PM | #13 |
Rep 43
Same issue even when I strongarm the lever, only noticed on driver's side. Anyone know if the left/right cables are independent? I wonder if the driver's side is loose because the passenger side is already tight.
