03-18-2019, 08:34 AM | #1 |
142
Rep 320
Hello, I will be due to replace all 8 of my pads and all 4 rotors in around 2000 miles. I have around 18000 miles on them currently.
Anyone know where I can get aftermarket pads that are better than oem? I just don't want any squeeling noise. Also I am looking for slotted rotors any brands that makes them for the g01? |
03-18-2019, 09:31 AM | #3 | |
142
Rep 320
I saw on the BMWparts website that these cars uses the same rotors as the G01 X3m40i: 530e Sedan. Required: 1 530eX Sedan. Required: 1 530i Sedan. Required: 1 530iX Sedan. Required: 1 540dX Sedan. Required: 1 640iX Automatic (B58). Required: 1 740eX Automatic (B48X) Sedan. Required: 1 740i Automatic (B58) Sedan. Required: 1 740iX Automatic (B58) Sedan. Required: 1 740i Automatic (B58) Sedan. Required: 1 740eX Automatic (B48X) Sedan. Required: 1 740iX Automatic (B58) Sedan. Required: 1 Can I go on another website and order slotted rotors for the 5 series and it will fit the X3M40i 2018 G01? |
03-18-2019, 09:37 AM | #4 |
10998
Rep 32,881
I meant with heavy use. With light use they'd last about 4 times that!
Are you sure the front rotor thickness is down to 28.4mm? And have you gone through 2 sets of pads? Each pair of rotors should last for 2 sets of pads regardless of the type of use. |
BMWZ41912.50 |
03-18-2019, 10:07 AM | #6 |
1913
Rep 5,110
Yeah, this seems a bit excessive. I drive the 401 every day and it's stop/go for 50kms each way. I've never replaced pads (or rotors) under 60,000kms...
You must be really stomping down on your brakes all day long lol EDIT: try Zimmermann brand for rotors if you don't want OEM. Pads, I don't have a recommendation. I'm sure others will chime in
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
03-18-2019, 02:05 PM | #8 | |
142
Rep 320
Wow I can't believe the maximum wear is 1.6mm. I must be very close to that or on it... for the pads I still have 30% left on them. |
03-18-2019, 03:16 PM | #9 | ||
10998
Rep 32,881
So are they the first set of pads? Are the rotors heavily lipped? |
iManu141.50 MechX3M40i1006.00 |
03-18-2019, 04:15 PM | #10 |
84
Rep 147
Wow. I would suspect you can get a lot more from your rotors. I put 55,000 miles on my M3 and over 40 days at the track with track pads and I still did not wear out original rotors. But I did go thru multiple track pads and one set of OEM pads.
I'm planning on not needing any brake maintenance in the first 40,000 miles. |
03-18-2019, 07:25 PM | #11 | |||
142
Rep 320
03-18-2019, 07:28 PM | #12 | |
142
Rep 320
03-18-2019, 07:40 PM | #14 |
1006
Rep 1,727
If you go through a set of rotors in less than 20k miles, that may mean your pads are eating the rotors for lunch. The last thing I would want to do is to put drilled discs there and risk getting them worn out even faster, or worse, cracked.
iManu141.50 |
03-19-2019, 02:33 AM | #16 |
544
Rep 382
Hi,
Our ML63 that we had before our X3M40i used to eat rear brake pads. Like our BMW - the ML had automatic cruise control. We are not heavy brakers - but the car is automatically applying the brakes regularly to control the speed when the ACC is switched on. As we do a lot of motorway driving - we use the ACC virtually all the time. First set of rear pads wore away in 18,000km - that was a real shock! Over a period of 44 months and covering 108,000km (67100 miles) - we got through many sets of pads and replaced front and rear rotors once. Every time we replaced pads - we had the rotors refaced. We changed the rotors once they got to minimum thickness. We used a German specialist to do the work - rather than the Mercedes dealer - but still spent a total of $4000 on parts and labour over our owenership period. Modern, performance SUVs with auto cruise will certainly eat brakes, it seems! Luckily - in Abu Dhabi, new BMW cars are supplied with an 8 year/160,000km service and maintenance package that includes brakes - so no more costs there! Cheers Steve |
MechX3M40i1006.00 iManu141.50 |
03-19-2019, 06:06 AM | #17 | |
1006
Rep 1,727
SteveX3M40i543.50 |
03-19-2019, 06:08 AM | #18 |
10998
Rep 32,881
Actually the opposite, the X3 has ‘performance control’ which applies more power to the outside wheels rather than braking the inside wheels. Also these modern cars have brake energy regeneration, which further reduces the amount the brakes are used.
03-19-2019, 06:40 AM | #19 | |
544
Rep 382
We tend to use ACC as a defence mechanism - due to the way other drivers switch lanes suddenly and swerve in front of you! It’s an added layer of safety - also bear in mind motorway speed limit is 140km/h (87mph) and you can overtake from either side! Cheers Steve |
03-19-2019, 10:54 AM | #20 |
513
Rep 914
03-19-2019, 11:12 AM | #21 |
10998
Rep 32,881
Brembo make the calipers, but I'm not sure who makes the discs, they're just stamped with BMW
