BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    New rear tires testing wheel spin with RC
      03-15-2019, 05:51 PM   #1
MV99
38
Drives: 2018 E63 , 2018 M5, 2019 B7
After returning from a month long trip and longer than usual rain season in Bay area, I finally got a warm sunny day to test RC map7 with set of new rear tires (got nail). Decided to stay with Pirelli p zero because front tires still have more than 65% left. Will try Michelin PS4 next round.
Temp was around 70 degree. The main purpose was to see if new tires could prevent spin with map7. I first tried it in stock for reference. Got 3.06 (2.87 with 1 foot roll) the first try in stock form. With new tires, I could wait more than 2 second to get it fully loaded and there was no wheel spin.
I turned on map7 for 2nd try. Waited 2 second and was glad that there was no spin on 1st gear but felt spin going into 2nd gear. The result was 3.13 (2.89) which was slower than that in stock form. I think that is mostly due to wheel spin.
The best 0-60 so far was with map6 with early releasing brake. It was 2.82 (2.60). I am really interested to know what is the potential improvement if there is no spin while doing LC fully loaded with map7. My guess PS4 may have better chance to achieve that.
      03-15-2019, 06:31 PM   #2
MV99
38
Earlier map6 result
      03-15-2019, 10:43 PM   #3
r33_RGSport
General
r33_RGSport's Avatar
12971
Drives: G09 XM, G05 X5 40, 991.2 T
What's your tire pressure?
Maybe drop it a bit to get more traction.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      03-16-2019, 02:35 AM   #4
MV99
38
Around 33 front 33.5 rear. I will try to lower tire pressure for few dragy runs to see if it improves wheel spin control. Thanks a lot!
      03-16-2019, 08:12 AM   #5
r33_RGSport
General
12971
I would drop it to 30 hot on the rear if you are running RWD only. Or all 4 if you are doing AWD.
It will give you much better traction.
Just don't go over pot holes with that.
      03-16-2019, 12:21 PM   #6
MV99
38
Will do so, thank you very much!! There are so much of new apartment construction going on right around Tesla where I drive to office everyday. The road condition is beyond words. I will bring my portable air compressor to Pump pressure back up after runs......
r33_RGSport12971.00
      03-18-2019, 01:58 PM   #7
limeypride
limeypride's Avatar
4425
Drives: 2022 M8 Competition GC
You might want to try short-shifting into second to minimize traction issues at the top of 1st. I haven't been able to try this myself but will do soon.
      03-19-2019, 02:19 AM   #8
MV99
38
I lowered pressure to 30 all around and tried few runs this afternoon. Wheel spin did improve (less spin going into 2nd gear) but I think the rolling resistance may have played some role and the time actually was slower...........3.03 (2.85) vs 2.82 (2.60). I was a bit surprised with the time but during acceleration I did sense the pull was not as strong compared to when pressure was set around 33-34 psi.
Driving with lower pressure with so much construction did get me concerned. Pumped it back to 33 afterward.
      03-20-2019, 09:21 AM   #9
r33_RGSport
General
12971
Hmm, that is weird.
      03-21-2019, 02:00 PM   #10
MV99
38
Hmm, that is weird.
This run looks more like it. The front tire was 31.5 and rear 32.5 and 0-60 without roll is 2.81 at slight uphill.
It was last evening with temp around 50 degree so wheel spun a little bit on test trial. I chose to do this run with slight early release brake. I think the time will be a bit better with warmer weather and lower pressure a bit more.
r33_RGSport12971.00
m5post
