01-05-2020, 03:17 PM | #23 |
Rep 18
01-05-2020, 05:22 PM | #24 |
80
Rep 241
If you read Dinan's reasoning for the design of their intake for the F48 X1, they admitted that the restriction is mainly in the tubing after the Airbox. It would have been more costly to produce an intake that incorporated the entire tubing tract, thus they made this particular intake for ease of installation and more affordability.
01-05-2020, 05:36 PM | #25 |
On the Go!
79
Rep 235
I got dinan on wife's car about a month ago. It's just a meh better (my feel). The air whooshing is slightly pronounced above 2500 rpm in sports mode (radio needs to be off).
I did this and the golf tee exhaust mod on the X1 few Sundays ago when it was still 50F outside and she thought it had a flash tune (it didnt). So point being; she noticed a bigger difference, what she called a throaty response but no noticable gain in power (on my butt dyno). She barely puts any miles on it and if we keep it past 2020 I may consider the recently released Noelle tune. If you need to see how it looks on the car or any help with the DIY let me know. Dinan had a 10% off MSRP sale which Intook advantage last month.
It doesn't matter if you win by a mile or inch, Winning is WINNING!
01-13-2023, 11:18 PM | #26 |
Rep 20
Proper
I was looking at BMS website and they mention the intake isn’t compatible with 2018+ F48 B48 Motors. It says it’s only compatible with 2015-2017 motors.. What year is your X1? I really hope that’s an error on the site. I want the intake! |
01-16-2023, 09:37 AM | #27 |
267
Rep 649
I believe it's because the MAF sensor changed.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
FabulousX1M1.50 |
01-16-2023, 11:00 AM | #28 |
303
Rep 1,084
Just saw this and figured I'd help you out with a little tip.. the X2 M35i model has the newer square MAF.. so if the 2018 X1 has it then I don't see why it wouldn't fit!
FabulousX1M1.50 |
01-17-2023, 02:21 PM | #30 | |
267
Rep 649
And I bought the additional cover to close it https://afepower.com/afe-power-54-12...e-system-cover With this aFe, you have the noise we want, with better hot air protection.
FabulousX1M1.50 |
01-17-2023, 05:51 PM | #33 | |
267
Rep 649
It should work on every pre-LCI model (i.e., before 2019). TBH, the picture I posted above was taken from there. But double-check the MAF sensor, just in case.
aFe states an improvement up to 13HP, which IMHO is too much to be true, but I didn't dyno it. Either way, you will probably get some extra HP after installing it.
FabulousX1M1.50 |
01-17-2023, 06:48 PM | #35 | |
267
Rep 649
TBH, I don't think it's worth it. Better replace the boost pipe and charge pipe (also from FTP), which I also did (read more here https://f48.bimmerpost.com/forums/sh....php?t=1681458). Or, you can go with an ECU flash to get much more HP from the B48 engine. I have ~275hp on mine, so it's highly recommended.
FabulousX1M1.50 |
01-17-2023, 06:53 PM | #36 |
Rep 20
jrveron
What company did you go with for flashing? I have been looking into that once I have the CAI. It seems like companies don’t offer very big HP gains as opposed to having a local tuner actually tune my ECU. I could probably get 80-90hp locally over ordering a flash/chip. Thoughts? |
01-18-2023, 09:32 AM | #37 | |
267
Rep 649
I can't state the real gain because I only dyno after it, and I got 275 hp, so I'm not sure if my F48 had 192hp (factory statement) or a little more. Either way, it's a 70+ hp gain and running only 91 octane gas. If you're referring to a dyno tuning, yes, the adjustment level is excellent, but in my mind, I should keep that if I'm planning to do some serious mod on the X1 (bigger turbo, intercooler, methanol, etc.).Also, you know, this kind of tuning is more expensive, and BTW don't forget to check if your DME is locked.
