03-13-2019, 12:37 PM | #1 |
2001
Rep 3,680
Dealer Wants Me to Wear out My Brakes...
Hey folks,
Kind of an odd-ball thread topic, but: My CPO warranty and Extended Maintenance plan both expire the 22nd of this month. Included in whatever Maintenance Plan I got when the car was purchased is a free brake job, pads and rotors. I never used it, but I can feel and see both through the pedal feel and by looking at the brakes themselves that they're going to be due for replacement soon. So I went to the dealer to hopefully cash in on my free brake job before the plan expires. The limit for them to replace the brakes under the Maintenance Plan (i.e. free to me) is 4mm on the pads. My rears are 5mm, my fronts are 7mm. They confirmed that all rotors are eligible for replacement. However, because my pads are above 4mm, they said they can't do any work, on the pads or the rotors. They won't replace the rotors independently of the pads obviously, and I wouldn't want them to, but because the pads are not eligible for replacement, neither are the rotors. I was obviously pretty unhappy with this, so I spoke with the Service Manager, and this is what he told me: We can't do any work on the brakes under the Maintenance Plan as you're brakes don't meet the replacement threshold. I asked, politely and professionally, if there was any way he could just help me out and do the job because I'm so damn close on the pads (the rears at least) and the rotors are ready to be replaced. He responded by saying that the brakes have to go back to BMW after replacement under the plan in order for it to be covered, and so I should go and drive around, and essentially try to wear out my brakes as much as I can, then come back on Friday to see if I'll qualify. I don't have anything going on this week, so I told him I'll see him on Friday. (I would've waited to come back the day the maintenance plan expires, but I'll be away, so this week is my last chance). TL;DR: Just barely not eligible for brake replacement under maintenance plan, Service Manager told me to go wear them out and come back in 48 hours. I said you're on. So my questions are as follows: 1. Is it true that they have to send my old brakes to some corporate BMW office in order for the work to be covered by the plan? Sounds a bit fishy to me, but I suppose it could be true. 2. How can I wear out my brakes as quickly as possible? My driving style is very kind to brakes typically, so I guess I'm going to have to drive like my father always taught me not to: ride the brakes. I'd go do a track day, but I don't want to wear on the rest of the car, and that's typically not an option this time of year. I don't want to just keep my foot on the pedal driving around, as that makes the engine work harder to keep speed, and is a nuisance to drivers behind me. Should I brake light and early, or hard and late? Just rack up miles? EDIT: After writing and re-reading this, I feel like I sound like a moron asking for the most efficient way to wear out my brakes, but whatever. Any ideas on how to get those pads down an extra mm in 48 hours, and I'd appreciate it.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
03-13-2019, 01:24 PM | #2 |
251
Rep 426
Back when I was first learning to drive, if my brakes squealed, I would take it up to about 65-70mph, then slam on the brakes just prior to the point of lockup to "re-surface" them... at least that's what my dad told me. Seems like it might work. I grew up in the country, so we would do this on back roads with nobody around so I wouldn't be brake-checking someone on the interstate.
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
rjd_F302000.50 |
03-13-2019, 01:53 PM | #3 |
18775
Rep 14,121
Drives: G82 M4C X-Drive
Yes, this is true they need to be 4mm or less. The best way to wear out brakes is to track the car!
BeerHerder has it right. From a high speed you need to apply quick and firm pressure (about 85-90%) right before the ABS kicks in. This is best done on the track or in the backroads. No need to come to a complete stop, but slow enough to enter the corner and then EASE off the brake as you hit the apex, then full throttle once you are pointed straight into the next turn, rinse and repeat. Don't forget to allow for active cool down (drive moderately for 5-10 min after the session) or your wheel weights will pop off.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
03-13-2019, 01:55 PM | #4 |
58
Rep 166
Do you have a bench grinder.... just sayin'.
Perry
2015 328i X-Drive, M-Sport, Cold Weather Pkg, Lighting Pkg, Premium Pkg, Harman Kardon, Black Grilles, Hands-Free, M-Perfomance side sills, X-Drive floor liners.
03-13-2019, 02:06 PM | #5 |
David
786
Rep 2,009
You can try driving with your left foot on the brake, or at night, go to an open road and do several 80-0 stops to simulate track abuse haha
03-13-2019, 02:07 PM | #6 |
1471
Rep 975
+1. A couple hot laps at Buttonwillow or Laguna Seca will take care of that no problem. Another way would be to go on the highway during off peak and take an exit ramp as if it was a corner at a track....brake late, hard, hit the apex and power out.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
rjd_F302000.50 |
03-13-2019, 02:08 PM | #7 |
8270
Rep 16,122
Probably not, but they probably do have to hold on to any parts replaced under warranty for inspection by BMW. The dealer I worked at did. Once inspected the warrantied parts were marked so that they couldn't be used again as proof of warranty work done, after which they were hauled off to a scrap metal facility.
rjd_F302000.50 |
03-13-2019, 02:13 PM | #9 |
Cheapskate
4450
Rep 4,995
I worked as a warranty engineer. We didn't always request parts back, but sometimes we did if the failure seemed fishy or if we needed help with root cause analysis.
For a maintenance plan we never did. However, I only worked on new vehicles (not CPO) so all maintenance was scheduled. It may be different for CPO plans that include wear items. Also it sounds like you kind of thought about it, but putting abnormal wear on your brakes while driving around town will definitely put abnormal wear on other components. Dragging brakes will put extra wear on your transmission, wheel bearings, etc. Just be careful if you're that committed. |
03-13-2019, 02:40 PM | #10 |
2001
Rep 3,680
Thanks for all the replies.
I know a track day would be best, and after the one I did last summer, I noticed that my brakes certainly took a beating, as expected. It would be ideal, but only having 48hrs prevents me from doing that, sadly. Either way, noted all suggestions and will get out and get to work on these brakes. Seems like high speed, high pressure slow-downs are the way to go. I was just out on my favorite backroad for nearly an hour giving them a workout, thankfully it's nice enough weather for it to be safe and enjoyable. I'll keep at it lol. Also- to the folks who commented about them having to send parts back/keep parts for verification, thanks for your input. Good to know they're not BS'ing me on that part, or at least not entirely. I'll update on Friday when I go back into the dealer regarding whether or not I was successful.
03-13-2019, 02:56 PM | #11 |
1061
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Yep..CPO was 4mm minimum on wifes X3 too. They wouldn't do it. These pads are pretty hardy so I doubt you can wear 1mm down in a week or so.....
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
rjd_F302000.50 |
03-13-2019, 04:03 PM | #14 | |
2001
Rep 3,680
Probably could find one, but I don't really feel like doing that. Sort of dishonest, and a hassle.
03-13-2019, 04:35 PM | #15 |
809
Rep 1,910
This is a better and safer solution than driving the car hard or in abnormal manner on short-term basis to run the pads down-
Of course you could just pass on the freebie thing and DIY pads and rotors when the time comes - pretty darn simple job and not very costly. |
03-13-2019, 04:38 PM | #16 |
1577
Rep 1,254
I know time is of the essence, but i'm willing to bet if you put a WTB on BMW forms for old worn brake pads--you could easily find a set.
03-13-2019, 04:50 PM | #17 | |
2001
Rep 3,680
kern4174449.50 |
03-13-2019, 05:32 PM | #18 |
Rep 3
I just got a used 2013 f30 and the discs on it have noticeable indents on them. Its my first car so im not too sure when i should get them changed out. Any advice?
03-13-2019, 06:16 PM | #20 |
773
Rep 1,502
I’d probably lightly left-foot brake while maintaining a constant speed instead of doing high-speed stops. Doing that for a half hour at highway speeds (be safe!) would probably do the trick. Give the brakes a little break (see what I did there?) every few minutes so you don’t warp your rotors or boil the fluid. Definitely stop if the brake pedal starts to feel soft.
rjd_F302000.50 |
03-13-2019, 06:27 PM | #21 | |
2001
Rep 3,680
kern4174449.50 |
03-13-2019, 06:43 PM | #22 | |
18775
Rep 14,121
