02-28-2019, 10:38 AM | #1 |
393
Rep 487
Ferrari F8 Tributo
THE FERRARI F8 TRIBUTO: A CELEBRATION OF EXCELLENCE
An homage to the most powerful V8 in Ferrari history The first photographs revealed ahead of official March 5th unveiling at Geneva Motor Show Maranello, 28 February 2019 – Ferrari has revealed the first official photographs of the F8 Tributo, the new mid-rear-engined sports car that represents the highest expression of the company’s classic two-seater berlinetta. The name is an homage to both the model’s uncompromising layout and to the engine that powers it – with a massive 720 cv and a record specific power output of 185 cv/l, it is the most powerful V8 in Prancing Horse history for a non-special series car and sets the benchmark not just for turbos, but for engines across the board. The 3902 cc V8 won “Best Engine” in the International Engine of the Year awards three years running in 2016, 2017 and 2018 and, in addition, in 2018, was awarded the title of the best engine of the last two decades. As these prestigious awards demonstrate, in the automotive world, Ferrari’s V8 engine is seen as the very epitome of sportiness and driving pleasure. This is particularly the case when it is mid-rear-mounted in a two-seater. Ferrari has been honing the scope of abilities of this architecture, which creates an optimal weight balance, to perfection for over four decades. The result is the F8 Tributo, which is one of the fastest, most thrilling and communicative supercars ever. The new car replaces the 488 GTB, with improvements across the board, providing even better control on the limit along with greater on-board comfort. The F8 Tributo punches out 50 cv more than the car it replaces, is lighter and benefits from a 10% improvement in aerodynamic efficiency along with the latest version of the Side Slip Angle Control, now in 6.1 guise. So while the F8 Tributo offers the highest levels of performance of any car in the current range, that performance is also very usable. The F8 Tributo delivers its 720 cv without the slightest hint of turbo lag and produces an evocative soundtrack. Instantaneous power is matched by exceptional handling thanks to advanced vehicle dynamics solutions. These include a new version of the Ferrari Dynamic Enhancer (FDE+) which can be activated in the manettino’s RACE position for the first time, a move designed to make performance on the limit easier to reach and control for an even greater number of drivers. The steering wheel rim is also smaller in diameter to enhance the level of tactility and make the car feel even more agile. In addition, weight reduction measures have cut the car’s dry weight by 40 kg compared to the 488 GTB, further enhancing both responsiveness and driving pleasure without impinging on interior comfort. State-of-the-art aerodynamic solutions incorporated into the car’s body help ensure that the extraordinarily powerful engine can be fully exploited. As with the 488 Pista, the F8 Tributo’s aero package is directly evolved from the track and it adopts several features from the 488 Pista designed to help manage engine heat, including, for instance, the rearward-angled front radiators and the dynamic engine air intakes positioned either side of the spoiler instead of on the rear flanks. Designed by the Ferrari Styling Centre, the F8 Tributo is essentially a bridge to a new design language that will continue to emphasise Ferrari’s key characteristics of high performance and extreme aerodynamic efficiency. The front of the car is characterised by the S-Duct, a solution that made its debut on the 488 Pista, but which has been redesigned to suit the extensive modifications made to this area of the car. The result is that the S-Duct alone contributes an impressive 15% to the overall increase in downforce compared to the 488 GTB. The new, more compact, horizontal LED headlights allowed Ferrari’s aerodynamicists to incorporate new brake cooling intakes in combination with those on the outside of the bumper, the aim being to improve air flow throughout the entire wheelarch and thereby avoid having to increase the size of the braking system to cope with the car’s greater speed. The new Lexan rear screen showcases the engine compartment and also brings a modern twist to the most distinctive design element from Ferrari’s most famous V8, the F40. The louvres help extract hot air from the engine compartment without impacting the efficiency of the blown spoiler which has been further evolved to increase downforce generated at the rear. The spoiler wraps around the tail lights, visually lowering the car’s centre of gravity and allowing a return to the classic twin light cluster and body-coloured tail, another signature of the early 8-cylinder berlinettas like the very first in the legendary series, the 1975 308 GTB. The cabin retains the classic, driver-oriented cockpit look typical of Ferrari’s mid-rear-engined berlinettas, but every element of the dash, door panels and tunnel, has been completely redesigned. The new generation HMI (Human Machine Interface), complete with round air vents, new steering wheel and controls as well as a new 7” passenger touchscreen display, significantly enhance the on-board environment for driver and passenger. Ferrari F8 Tributo Technical specifications ENGINE Type 90-degree V8 turbo Overall displacement 3902 cc Max. power output* 720 cv at 8,000 rpm Specific power output 185 cv/l Max. torque 770 Nm at 3,250 rpm DIMENSIONS AND WEIGHT Length 4611 mm Width 1979 mm Height 1206 mm Dry weight** 1330 kg PERFORMANCE 0-100 km/h 2.9 s 0-200 km/h 7.8 s Top speed 340 km/h |
02-28-2019, 12:31 PM | #3 |
6477
Rep 1,966
Nice car, is it just me or does the rear end look corvette-ish?
stevenvillatoro734.50 |
02-28-2019, 02:37 PM | #5 |
6069
Rep 3,626
waiting to see where 458 prices go now that Ferrari is staying with turbos. Would have thought that with so many complaining they would go to a NA+hybrid setup like the 918.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
02-28-2019, 03:14 PM | #6 |
1458
Rep 2,336
Looks like a 488 without the stripes and different back cover sorta.
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD |
02-28-2019, 03:35 PM | #8 | ||
4463
Rep 9,160
02-28-2019, 03:59 PM | #9 | |
6477
Rep 1,966
https://www.carmagazine.co.uk/car-ne...18-cayman-gt4/ |
Red Bread4463.00 |
02-28-2019, 04:00 PM | #10 | |
6477
Rep 1,966
03-01-2019, 10:54 AM | #13 | |
6069
Rep 3,626
Usually Ferrari does 10 year model runs with a moderate update in the middle. The 360/430 were mostly the same chassis but they updated most of the running gear and engine. The 458/488 again were the same car basically with an updated exterior and engine. The F8 tribute looks basically like another update instead of a whole new car from the ground up. The engine is the same one in the 488.
NickyC17484.50 |
03-01-2019, 11:06 AM | #14 |
730
Rep 1,087
Definitely better looking than the 488 which already looks pretty nice. But for the money, if you're going to get a Ferrari, the 458 Speciale is the one.
IllSic_Design2124.00 |
03-01-2019, 11:07 AM | #15 |
4463
Rep 9,160
See, now you're actually making sense. I hate to think of how you'll take the likely hybrid version of the F8 that's soon to come.
03-01-2019, 08:08 PM | #17 | |
730
Rep 1,087
03-05-2019, 10:27 AM | #20 |
2893
Rep 3,470
Exactly this. Late-model refresh. Like a 2019 Camaro...you know
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
