02-22-2019, 02:11 PM | #1 |
60
Rep 105
Drives: 2018 BMW X5, 2019 850i C
Bimmercode App M5
Hello, I'm new to this forum and just took possession of a fully loaded 2018 M5. I was wondering if anyone has used Bimmercode successfully on their M5 and if so, what did you change? As a side note, I ordered the RaceChip GTS that I'm anxious to install. Would love to gather peoples thoughts...
p.s. I know this isn't the best photo... Last edited by BMWCARGUYM5X5; 02-22-2019 at 02:16 PM.. |
02-22-2019, 02:56 PM | #2 |
325
Rep 519
Used it plenty. Works great but you have to make sure to get a UNicarscan adapter. In the last iOS update it was clearly indicated that you needed this tool to access all the modules.
Here is what I have done ASD off Full text message Ambient light red Adjust the angle of passenger mirror tilt on reverse Opted out of warning message on startup Seat belt warning off Zoom in rear camera M animation on IDrive Flashing brake force display Lane departure warning at 55 km/h There is a few other things but off the top of my head that's it |
jprider4.50 |
02-22-2019, 03:00 PM | #3 |
60
Rep 105
Thank you so much for the information. Have a good weekend.
02-22-2019, 03:17 PM | #4 | |
4425
Rep 4,109
Media playback … I don't know if you can do VO code outside of E-Sys. |
Aronis2273.00 gioM5-Comp32.50 |
02-22-2019, 06:30 PM | #6 | |
325
Rep 519
https://www.obd-2.de/shop/profi-diag...iagnoseadapter |
utsteve98129.00 |
02-22-2019, 06:32 PM | #7 |
129
Rep 188
Ha. Thanks. I guess I need to learn German or get google translate
02-22-2019, 07:04 PM | #9 | |
194
Rep 459
Where is the option for "Seat belt warning off" ?
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package 2013 Lamborghini Aventador-Pearl Green-Modified 2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White |
02-22-2019, 07:09 PM | #10 | ||
325
Rep 519
02-23-2019, 08:21 AM | #11 | ||
325
Rep 519
02-23-2019, 08:24 AM | #12 | |
General
12971
Rep 18,716
You'll enjoy the RaceChip. Bimmercode doesn't do VO coding. And it is still limited, unlike E-Sys. I have suspicion that Carly and Bimmercode who made Tokenmaster not opening his Launcher for public anymore. Since those two companies are making money out of his work.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-23-2019, 08:24 AM | #13 |
60
Rep 105
What option is the break light flashing under and the anti-dazzle headlamps?
02-23-2019, 08:41 AM | #14 |
325
Rep 519
05-06-2019, 09:10 AM | #15 |
194
Rep 459
I have the "vgate" obd adapter which worked fine with Bimmercode on the F10 m5.....but now certain coding sections give the error "a unicarscan or obdlink adapter is required for conding this control unit" .....which adapter models have you purchased in USA that works? any amazon link?
05-06-2019, 10:43 AM | #16 |
51
Rep 31
I am in Texas, and ended up buying a UniCarScan unit from this outfit in Germany:
https://www.obd-2.de/shop/profi-diag...iagnoseadapter You can copy and paste the link in Google Translate to read the site in English, or some browsers will do the translation for you. Smooth transaction for me -- no problems. It took a couple of weeks to get the unit delivered. It's worked very well with Bimmercode for me. If you're adamant about buying from a US site, Bimmercode says this one works (Amazon link): https://www.amazon.com/OBDLink-Bluet.../dp/B07JFRFJG6 Good luck, B B |
05-06-2019, 11:27 AM | #17 |
194
Rep 459
thanks! trying to get the annoying seat belt chime removed!
05-10-2019, 12:59 PM | #18 |
266
Rep 770
Just received this from amazon and downloaded bimmercode.
Gonna start changing stuff and hope I don’t screw anything up. Here goes nothing...
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7 |
05-12-2019, 02:01 PM | #19 |
Rep 13
05-12-2019, 03:17 PM | #20 |
31
Rep 113
Can confirm that OBDLink MX+ works with Bimmercode.
Did ASD, different ambient lighting color, startup message, lane departure. Now just need to figure out what some of the other items are.
2019 F90 M5 Comp | Marina Bay Blue, stealth PPF
2016 F80 M3 | Mineral White - sold 2011 E92 M3 | Jerez Black - sold 2001 E46 M3 | Carbon Black - sold |
05-13-2019, 06:03 PM | #21 |
4425
Rep 4,109
No. Partially done using E-sys but it's not perfect.
02-02-2020, 12:17 AM | #22 | |
Sith Lord
Rep 32
