Oil Pan Bolt Question
02-21-2019, 09:03 AM | #1 |
Rep 35
Hi all - I believe I have cross threaded where one of the oil pan bolts screws into the engine. I'm going to try to correct with a tap, but I can't find the specifications for the bolts themselves, so I don't know which tap kit to buy. Can anyone help me out? I need the size (M8?) and the thread pitch.
Many Thanks, -j |
02-21-2019, 09:12 AM | #2 |
Clean is the new cool, keep it that way.
808
Rep 1,685
take a bolt out and go to any place that sells fasteners and find out.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive |
02-21-2019, 09:40 AM | #3 |
Rep 35
Thanks for replying - yeah, I planned on doing that if no one had the specs handy - just trying to get the right kit ordered and hopefully delivered by the end of the day to save some time and money.
-j |
02-21-2019, 11:06 AM | #5 |
719
Rep 1,753
02-21-2019, 12:07 PM | #7 |
808
Rep 1,685
And unless the threads are really messed up, you should be using thread chasers (cleaners) not taps.
02-21-2019, 01:03 PM | #9 |
General
17364
Rep 18,757
My research shows the bolt is an M8 x 1.25 pitch. To retap the hole you'll need a blind-hole, or bottoming M8x1.25 tap. A through-hole tap, which are the most commonly sold, will not fully tap the hole in the block. A thread chasing tap should be a blind-hole tap configuration.
The bolt set P/N is 11132210959. FCP Euro shows the bolt size as M8x1.25 in several lengths. As stated, use a chaser not a tap unless it is a bottoming tap. You should have the old bolts to check against. I recommend that any good tool set have a bolt size gauge kit. Hint hint. Last edited by Efthreeoh; 02-21-2019 at 01:12 PM.. |
02-21-2019, 01:34 PM | #11 | |
Beamer Mantic
82
Rep 1,191
Edit: with Eye protection!!!
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
02-21-2019, 02:10 PM | #12 |
808
Rep 1,685
I mean really anytime you remove bolts you should use thread cleaners. It's not a problem until it is but when you don't and shit goes wrong it sucks. All it takes is a bit of debri to make a simple job into a nightmare. Been there, done that.
02-21-2019, 03:25 PM | #13 |
Grandmaster
776
Rep 803
When I had my engine on a stand and was replacing the oil pan bolts, the threaded holes that the bolts go into had crap in them, not sure if it was loctite or what.
Anyways, my point is that before I installed the new oil pan gasket and bolts, i took an old bolt, and dremeled a slit along it to act as a kind of ghetto thread chaser and ran it through each hole. It made the new bolts go in much easier and you could actually feel when the bolts were bottoming against the oil pan instead of feeling them gum up with whatever crap used to be in those threads. In some cases, my torque wrench would click well before the bolt actually seated against the oil pan, purely from the threads being all gummed up. I was "lucky" enough to have my motor on a stand for this so I'm not sure how much room you have underneath, but if at all possible, I agree with the guy above me, run a chaser through there if you can before reinstall.
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 |
9krpmrx8808.00 |
02-21-2019, 04:39 PM | #15 | |
General
17364
Rep 18,757
02-21-2019, 06:17 PM | #16 |
Grandmaster
776
Rep 803
They do. I think this is what I was feeling, leftover thread locker.
