Bimmerpost
4 Series
Technical Topics Suspension / Chassis / Brakes Any details on the G20 M performance brakes?
      02-18-2019, 12:52 AM   #1
dave72
BMW M2
dave72's Avatar
497
Drives: BMW G87 in order
Have anyone the full details, pices off the big M performance brakes for the new 3 series?
DZ F30303.50
      02-18-2019, 10:52 AM   #2
Pauleebe
Pauleebe's Avatar
380
Drives: Inbetween BMW's.
Are these the same brakes that are included in the Track Handling Package? Or is this the "next stage" beyond what that package includes?
      03-06-2019, 06:19 PM   #3
upsidedownfunnel
1996
Drives: 2014 335i
2014 BMW 335i  [0.00]
I'm just guessing, but these look like the same calipers that are on the M Sport with unique rotors and probably different pads. Thesse are just 4 piston calipers that are made to look much larger. The larger caliper probably does improve heat dissipation and rigidity, but it's obviously mostly intended to be aesthetic. Pretty lame design, IMO.
      03-07-2019, 07:04 AM   #4
stvding
stvding's Avatar
662
Drives: G20 M340ix
Shame it is not 6 pistons. It is not that much more expensive.
      04-10-2019, 08:25 AM   #5
BMW435
BMW435's Avatar
Switzerland
345
Drives: BMW 435
Can you choose the color of the m perf breaks ?
      11-03-2019, 01:46 PM   #6
jcrosa
Brazil
13
Drives: BMW X5 45e M Sport 2022
Does anyone have the technical specs of this brake kit?
It is an expensive accessory and I'm not able to find any detailed information about it...
      11-04-2019, 08:48 AM   #7
BMW_Belgier
BMW_Belgier's Avatar
Switzerland
99
Drives: E92 335xi n55
https://www.ff-tuning.de/performance...ot-3er-g20-g21
BEFORE: 130i N52 (2006-2011)
NOW: 335xi N55 (2011- )
      11-09-2019, 08:10 PM   #8
jcrosa
Brazil
13
Originally Posted by BMW_Belgier View Post
Thanks! And also thanks for Google Translator helping me dealing with German...
      01-23-2020, 06:20 PM   #9
R99
1099
Drives: 2016 330d F31 Touring
G20 M Perf are 374mm only, unlike the G30 / G11 M Perf option which is a 395mm caliper body.
I have tested the G30 / G11 395mm caliper (with disc) on the G20 hub and it fits perfectly.
If anyone is interested, I have several sets of 374mm and 395mm calipers for sale in the classifieds
      01-23-2020, 08:25 PM   #10
CrownRoyal79
CrownRoyal79's Avatar
284
Drives: BMW 435i
EDIT: 374 x 36mm front slotted disc, 345 x 24mm rear slotted disc
https://www.schmiedmann.com/en/catn-ol?q=34112450161
      01-24-2020, 03:52 AM   #11
R99
1099
I know this information already!
As I said the G20 only gets the 374mm M Perf option, not the 395mm.
As for the rear, if you have the M Sport blue brakes already, then this M Perf kit just supplies you an identical caliper - just painted red - with the addition of a dimpled / slotted disc.
The same applies to m340i owners who may have optioned the front 374mm blue M Sport brakes already - this kit simply adds an identical caliper body - but painted red!!
It’s a waste of money if you already have the 374mm brake kit in M sport format. You can literally paint your calipers, add the M Perf rotors and you have an identical set up to the one you linked, for less cost.
If you have 348mm M Sport brakes then again you are simply replacing your rear caliper with an identical size with this kit.... only the front will increase in size to 374mm.
My point was simply that there are much cheaper ways to add either 374mm or 395mm, and you are not limited by the red only colour of the M Perf kit!
      01-24-2020, 06:22 AM   #12
CrownRoyal79
284
Drives: BMW 435i
It's a waste of money if you already have the 374mm brake kit in M sport format. You can literally paint your calipers, add the M Perf rotors and you have an identical set up to the one you linked, for less cost.
The red M-Performance brakes are the same size as the the blue brakes that are included in the track handling package. The only question is, are they the same caliper with different paint? Same pads?
It would be really lame if BMW slapped some red paint on the SAME calipers, gave you some slotted (not drilled) rotors and called it M-Performance.
      01-24-2020, 12:09 PM   #13
R99
1099
That is literally what is happening.
The caliper body is identical in every way, with the exception for the red paint.
Brake pad part number (34106888459) is the same for both the red M Perf brakes and also cars optioned with S33TA.
Appreciate 2
      03-10-2020, 09:31 PM   #14
kensiah
Malaysia
Drives: 2014 F30
If I choose the g30 m performance caliper, can use the f90 rotor? The specifications are also 395mm x 36mm
      03-15-2020, 07:27 AM   #15
blau3er
1147
Drives: F31 30d
You can't use the F90 M5 rotor, I have a set of F90 M5 brakes to hand here and I have tried the ///M rotor on a G20 hub, using a G11 395mm blue brake caliper.
The X3m however, uses a 395x36 ///M disc also, and I have photographs from a contact in Germany showing it all bolting up on a G20 hub.
The only issue is the location hole for the disc retaining screw, which does not line up with the G20 hub.
jcrosa12.50
      03-25-2020, 07:20 PM   #16
kensiah
Malaysia
Drives: 2014 F30
Thumbs up
thanks for sharing.
      03-26-2020, 03:44 PM   #17
blau3er
1147
Drives: F31 30d
No problem!
      03-26-2020, 05:03 PM   #18
jcrosa
Brazil
13
Do you suggest this set to upgrade the brakes of a G20? How much does it cost at the end of the day?
      03-26-2020, 06:05 PM   #19
Krabbypatty
81
Drives: BMW M340i xDrive
2020 BMW M340i  [10.00]
In the U.K. we have M technology package which is different to the technology package. I have attached a picture, I'm not sure if this gives you bigger brake discs or not. Can anyone clarify?
      03-26-2020, 06:08 PM   #20
Burrcold
5315
Drives: 2024 M3 Comp xDrive
Yes it does.
Savoir9.50
      03-26-2020, 06:09 PM   #21
Krabbypatty
81
Yes it does.
So what's the brake size compared to the standard m340i brakes? And are the discs any bigger/better?
      03-26-2020, 07:00 PM   #22
blau3er
1147
Drives: F31 30d
Standard m340i gets 348mm discs and a smaller caliper body
Optional brakes (part of the package) are 374mm and the caliper body is substantially larger, so fills the wheel much better!
Still not as big as the G3x & G1x 395mm set ups though, which is an even larger caliper body - officially this is not available for G2x cars, but I can verify that they fit....
g20
