ABS Module for 07 RWD 328i
01-25-2019, 01:07 PM | #1 |
30
Rep 143
Friends- I need to get a replacement ABS module pump for my RWD 328i. What do I need to know about buying a used part online?
1. I took a picture of my current pump and can't seem to find an another used pump with same part number? As long as I get a RWD 2007 328i pump I should be okay, correct? 2. What do I need to know about having the module recoded? Thank you!! |
01-25-2019, 01:31 PM | #2 |
54
Rep 140
I bought an used DSC pump for my 2005 E87 118d, I also noticed that theres hundreds of different part numbers.
I found out that there's a difference between the pumps on 4-cyl and 6-cyl cars. I ended up buying a used pump from a 2012 e90 316i, it worked fine after changing VIN and coding. If I remember correct, I had to change VIN using tool32, then code from VO with NCS expert and initialize some dsc stuff through ISTA I guess that you can do the same with a 6-cyl pump from any 1- or 3-series |
