BMW M5 F90 (2018+) General Forums Cosmetic Modifications    3.75" Slip-On Exhaust Tips for F90 - DIY
      01-24-2019, 12:22 AM   #1
hybrid_eg
hybrid_eg's Avatar
852
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
I wanted to share a simple and relatively inexpensive DIY upgrade for those who didn’t want to purchase an exhaust system, yet are looking for an overall stealthier look or simply wanting to match the remaining blacked out trim. I did the same on my F85 which is a bit easier as it doesn't involve any cutting.
I bought the 3.75” slip-on tips from Burger Tuning for $100 with shipping.
They are currently on sale until they sell off the remaining inventory (see link below).. I do not think they will carry these afterwards so you may want to get yours ASAP if you’re interested in doing this mod. They don’t have black in stock, only chrome or burned blue. You can get either one and powdercoat them black. I had mine done in gloss black along with stock tips for ($68). This brought grand total for this mod under $170.
The tricky part of this install is to extend the existing slot to a total distance of 2-3/8" which will ensure tips do not stick out too far from edge of the bumper. It will also ensure that inner pipe is wedged into double edge oversized tip you are installing for a firm fit. I cut the slot on mine using a grinder wheel. I marked my lines with a marker, drilled at the end point and made the cuts using grinder wheel. Once this is done i bent the tabs (as per instructions on the pics) to ensure they go on smoothly without massive pressure needed. Once i test fitted each tip i took them to powdercoater.
Keep in mind this is biggest tip you can run on F90 as the distance between each tip is merely 3mm give or take. I personally love the look and how it fills up bumper tip opening. See pics to judge for yourself.
BMS can thank me later for helping them move their close-out inventory tips!
http://www.burgertuning.com/exhaust_...M3_M4_BMW.html
Appreciate 3
Aronis2270.00
Redacre369.00
      01-24-2019, 06:39 AM   #2
Adris
Adris's Avatar
Lithuania
136
Drives: BMW F92 M8
very interested in this, but the link seems not working?
      01-24-2019, 09:15 AM   #3
Steeve19M5CP
194
Drives: 2019 MBB Blue M5 Competition
This link correct? ..so M4 tips will fit the msport exhaust F90 competition tips?
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package
2013 Lamborghini Aventador-Pearl Green-Modified
2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified
2018 Range Rover Velar S-White
      01-24-2019, 09:48 AM   #4
Adris
Adris's Avatar
Lithuania
136
Drives: BMW F92 M8
just placed an order on them, will give it a try
      01-24-2019, 12:57 PM   #5
Steeve19M5CP
194
I confirmed with BMS this will not fit the competition M5 tips
      01-24-2019, 08:02 PM   #6
hybrid_eg
hybrid_eg's Avatar
852
I’ve updated the link. No need to check with BMS their link says it only fits F80/82, I tested it and it works on F90 base. See pic below with stock F90 tip measurements I took. Basically remove your tips with a mallet on Comp and determine if it’s same size, it should be.. however I cannot confirm as I don’t have a comp package vehicle to test.. if it’s same size this Mod will work. As far as I understand base vs comp difference is just black exhaust tips.
      01-25-2019, 03:26 AM   #7
Adris
Adris's Avatar
Lithuania
136
Drives: BMW F92 M8
I have just checked my exhaust, I have comp exhaust and I can confirm that diameter is exactly the same as per your pictures 75mm at the end.
      01-25-2019, 12:09 PM   #8
Steeve19M5CP
194
nice!
      01-25-2019, 02:10 PM   #9
Steeve19M5CP
194
so on the competition model......you guys think the BMS black tips or chrome look better? I am on the fence
      01-25-2019, 05:03 PM   #10
josec70
josec70's Avatar
4065
Drives: 22' Individual Chalk M5C
Black
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      01-25-2019, 05:47 PM   #11
Adris
Adris's Avatar
Lithuania
136
Drives: BMW F92 M8
black tips out of stock, so I have ordered chrome and I will coat them in gloss black
      01-25-2019, 07:20 PM   #12
hybrid_eg
hybrid_eg's Avatar
852
Order whatever color they have left and coat whatever color you like or chrome them.. whatever floats your boat.. this is just a cheap DIY for enlarged tips for those who don’t want to buy a full exhaust.. lastly these won’t last, one BMS sells them out that’s it..
      01-26-2019, 08:31 AM   #13
Steeve19M5CP
194
I was going to order the chrome's ...but then painting it gloss black wont look right....it needs to be chrome black like oem.....I think powder coating is the only option or is there a spray can with chrome black?
Also machining that slot isn't for your average DYI Joe
      01-26-2019, 07:40 PM   #14
Steeve19M5CP
194
I would do these instead?
https://f10.m5post.com/forums/showthread.php?t=1527878
https://www.amazon.com/AeroBon-Carbo...5+exhaust+tips
      01-26-2019, 09:31 PM   #15
hybrid_eg
hybrid_eg's Avatar
852
Steve, if you want them back Powdercoat then black just as I did. The F10 MPE style CF tips I do not know if they would fit.. plus keep in mind you will have to cut off the rods off the oem inlet pipe if you decide to go that route
      01-27-2019, 08:53 AM   #16
///M5_FAN
12
Drives: BMW
Good day, what the numbers mean 2-3/8’’, can you tell me how many centimeters total is new slot?
      01-28-2019, 05:01 PM   #17
hybrid_eg
hybrid_eg's Avatar
852
If you look at the first picture it says to extend the slot to a total length of 2-3/8" (inches). This translates to 60.325mm (millimeters)
      01-29-2019, 12:30 AM   #18
///M5_FAN
12
Drives: BMW
Thank you very much.
      01-30-2019, 07:48 PM   #19
Spoolin Montego
Spoolin Montego's Avatar
601
Drives: 16 m3/20 x5m/23 m3
Ordered these up but They don't fit my comp muffler..
      01-31-2019, 11:37 AM   #20
Adris
Adris's Avatar
Lithuania
136
Drives: BMW F92 M8
got them on, now the rear looks much better
      01-31-2019, 12:01 PM   #21
Poleposition
Poleposition's Avatar
514
Drives: very well
Why not? Even after cutting them as described in this thread?
2022 Individual M5 Comp
Venetian Violet
2021 X6M Comp
2024 i4 M50 on order
IG @purpleM5Comp_NY
      01-31-2019, 06:34 PM   #22
Spoolin Montego
601
I'm not very good at reading lol. Will try to find some time to cut them
m5post
