DSC coding
01-21-2019, 12:10 PM | #1 |
25
Rep 58
DSC coding
Good afternoon all,
In the subforum X5/X6 on this forum I placed a question about the coding of the DSC of an E70, but since the X5/X6 forum is not as comprehensive as the 3series-forum, I would like to notify you guys of the existence of my post, and hopefully someone of you can help me solving this issue. Please see here for the link to the original post: https://www.xbimmers.com/forums/show....php?t=1575668 Is there someone who can help me with the problem: not possible to code the DSC of my E70? Thanks in advance and best regards Hendrik Zeilstra. |
01-21-2019, 01:02 PM | #2 | |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
01-21-2019, 01:55 PM | #3 |
529
Rep 2,503
What is the problem with the old DSC? If it's the pump the actual DSC unit will be fine.
Just swap the new pump onto the original DSC unit. No coding required. Just bleed the brake and perform the DSC Adjustment with ISTA D. |
01-21-2019, 02:37 PM | #4 |
25
Rep 58
Thanks for the prompt replies!
Below the answers: - I have ISTA-D. Tried steering angle procedure, but at the end of ISTA said that it did not succeed. I did not do the valve calibration yet. I will try this tomorrow and come back to you with the answer. - The old DSC was faulty (former owner jumpstarted with polarity reversed, toasting a number of modules). After 10 weeks of measuring and replacements I now only have major problems with the FRM3 and the DSC. I updated all modules with SP-daten 53. I will also try with V66 as soon as possible. All suggestions are still welcome! Best regards Hendrik. |
01-21-2019, 03:14 PM | #5 | |
Sua Sponte
1299
Rep 2,850
If I remember correctly, when I replaced my 335i ABS/DSC unit with a M3 unit I flashed it with WinKFP to update the VIN, then ran DSC valve calibration and some operational routine, then I think you have to do the steering angle reset, if ISTA doesn't work you can try Tool32, and then you should be able to default code it with NCS Expert. I know NCS Expert won't work until these other things are done and errors gone, at least for me it didn't.
Unknown_Car447.00 |
01-22-2019, 11:48 AM | #6 |
25
Rep 58
Thanks again for the answers. Below the answers:
- I cannot find the valve calibration in ISTA-D. I think this procedure is not available for the E70. Adjusting steering sensor was not succesfull in ISTA. - In tool32, reading parameters is possible, but writing parameters is not possible. Changing VIN is not possible. It returns 'ECU conditions not correct'. - The same error is returned in NCS-expert when I try to write something to the DSC. Equal to Tool32, reading is also possible with NCS... I also changed the VIN back to the former VIN with WINKFP. Now all the VIN's are reading the same (but not correct to the car). This did not influency the results from above. Anyone having another idea? Thanks again! Best regards Hendrik Last edited by heze; 01-22-2019 at 02:34 PM.. |
01-22-2019, 01:46 PM | #7 |
31
Rep 79
Hi,
I have had assistance on this forum to get my DSC coded. It didn't go through at first attempt, but I got it working after a couple of attempts. You describe 'Now all VINs are reading the same' Yes, that would be one of the conditions before you can get your DSC working. Have you fitted some second hand modules to your vehicle? Second hand DME, CAS etc? For the steering angle sensor calibration, one of the advices here was to wriggle the steering wheel slightly while sending the command. Only like 0.5 degree movements. Can't tell you 100% if that is necessary, but I felt that it helped in getting the command through. Then I had problems with the pressure sensor calibration sequence. I probably had some air bubbles still in the system, so it took several retries before the DSC accepted it as successful calibration. I also used the ProTool app for some of the steps, not only the BMW tools. It could be worth a try, as the app may have fewer 'checks' before allowing you to do certain things. Cheers, |
01-22-2019, 02:19 PM | #8 | |
529
Rep 2,503
- code DSC with NCS Expert Expert Mode - ISTA D Steering angle Adjustment - ISTA D DSC Adjustment (you call it calibration) Then it should be fine. I'm pretty sure changing the vin is not essential. |
JJT2110.00 |
01-22-2019, 02:25 PM | #9 |
25
Rep 58
Good afternoon sir,
Thanks for your response. The VIN inside the DSC is now equal (read via Tool32 is the same as read from INPA), but this is the former VIN and not equal to the rest of the car! Lots of modules have been changed (VDM, FRM, DSC, CA). I will try to check the VIN of all the modules but I can only see the last 7 digits of the VIN. The VIN of almost every module was changed / corrupt because of the reversed polarity jumstart by the previous owner... Most of them are back to the original VIN number now... DME and CAS (the two with the VO inside) did both survive. Did you do this procedure for an E70 or another car? I do not recognize the pressure test as you are explaining in your message... In case someone wants to log in via team viewer, we can arrange this. Thanks again! Best regards Hendrik Last edited by heze; 01-22-2019 at 02:30 PM.. |
01-22-2019, 02:28 PM | #10 | |
25
Rep 58
- Coding is not possible, it returns error 'ECU condition not correct' in Tool32 and also in NCS-expert. This is my main problem at the moment. - ISTA D steering angle adjustment procedure did not succeed. With best regards Hendrik |
01-22-2019, 03:11 PM | #11 |
25
Rep 58
So a small wrapup of the problem on my E70 BMW X5:
- Programming the latest firmware in the DSC was succesfull both with ISTA-P and WINKFP. - Standard coding was rejected by ISTA-P, Tool32 and NCS-expert. Error ISTA-P: SYS0005: ECU description file not found Error Tool32 and NCS-expert: Ecu conditions not correct or request sequence error. It is also not possible to change the VIN with Tool32. It returns the same error from above. Main question is: what are the ECU conditions which prevent the DSC from coding...? Last edited by heze; 01-22-2019 at 03:19 PM.. |
01-22-2019, 03:46 PM | #12 | |
529
Rep 2,503
01-22-2019, 06:34 PM | #13 | |
Sua Sponte
1299
Rep 2,850
01-23-2019, 12:36 AM | #14 | |
25
Rep 58
In INPA (UIF) it can be seen that the VIN is changed to the CAR's VIN, but when I read the VIN with Tool32 (c_fg_lesen), it still displays the old VIN-number. Try to change the VIN in Tool32 with (c_fg_schreiben and c_fg_auftrag) resulted in the error message 'ECU conditions not correct' again. Two different VIN's in one ECU seems not right, so I flashed the ECU again with the original number. Now the VIN reads the same in INPA and Tool32, but it is the former, not the correct VIN. This did not help --> coding is still not possible. With best regards Hendrik. Last edited by heze; 01-23-2019 at 12:41 AM.. |
01-23-2019, 10:11 AM | #17 |
25
Rep 58
01-23-2019, 10:27 AM | #18 |
25
Rep 58
After clearing the errors, the error memory remains empty for about 5 minutes, after that the following errors are present in the DSC:
E R R O R M E M O R Y --------------------------------------- Date: 23.01.2019 17:23:30 ECU: DXC_70 JobStatus: OKAY Variant: DXC_70 ------------------------------------------------------------- RESULT: 6 error in error memory ! ------------------------------------------------------------- 5E6D 5E6D - F-CAN: Botschaft SYNC; ID 0x080) konnte nicht abgeschickt werden; von DSC-SG gesendet --- (DSC: unbedeutender CAN-Fehler: Fehlerspeicher loeschen) kein passendes Fehlersymptom Testbedingungen erfüllt Fehler momentan nicht vorhanden, aber bereits gespeichert Fehler würde das Aufleuchten einer Warnlampe verursachen Error code: 5E 6D A0 ------------------------------------------------------------- D359 D359 - F-CAN: Botschaft LENKRADWINKEL_OBEN (ID 0x0C9) nicht empfangen (von DSC-SG empfangen). [Sender: SZL] --- (DSC: F-CAN Botschaft (SZL 0C8) fehlt) kein Signal oder Wert Testbedingungen erfüllt Fehler momentan vorhanden und bereits gespeichert Fehler würde das Aufleuchten einer Warnlampe verursachen Error code: D3 59 E4 ------------------------------------------------------------- D36D D36D - CAN: Botschaft BEDIENUNG_TEMPOMAT (ID 0x194) nicht empfangen oder falsche Botschaftslaenge (DLC). [Sender:SZL] --- (DSC: F-CAN Botschaft (SZL, 194) fehlt) kein Signal oder Wert Testbedingungen erfüllt Fehler momentan vorhanden und bereits gespeichert Fehler würde das Aufleuchten einer Warnlampe verursachen Error code: D3 6D E4 ------------------------------------------------------------- D36E D36E - CAN: Botschaft BEDIENUNG_WISCHER (ID 0x2A6) nicht empfangen oder falsche Botschaftslaenge (DLC). [Sender:SZL] --- (DSC: F-CAN Botschaft (SZL, 2A6) fehlt) kein Signal oder Wert Testbedingungen erfüllt Fehler momentan vorhanden und bereits gespeichert Fehler würde das Aufleuchten einer Warnlampe verursachen Error code: D3 6E E4 ------------------------------------------------------------- 6EC8 6EC8 - Codierung Fahreranwesenheit fehlgeschlagen --- (DSC: Codierung wiederholen) kein passendes Fehlersymptom Testbedingungen erfüllt Fehler momentan vorhanden und bereits gespeichert Fehler würde das Aufleuchten einer Warnlampe verursachen Error code: 6E C8 E0 ------------------------------------------------------------- D36C D36C - CAN: Timeout der Botschaft BEDIENUNG_AUDIO_TEL (ID ox1D) --- (DSC: F-CAN Botschaft (SZL, 1D6) fehlt) kein Signal oder Wert Testbedingungen erfüllt Fehler momentan vorhanden und bereits gespeichert Fehler würde das Aufleuchten einer Warnlampe verursachen Error code: D3 6C E4 ================================================== =========== Summarized in English: Four failures are about the SZL (cluster steering angle, cruise control, wipers, buttons on steering wheel). This is normal because the SZL will be initialized and set up after coding of the DSC. One error means that the coding of the SZL is not functioning well. The last error is an 'unimportant can error: erase error memory' as google translates from German. Best regards Hendrik Last edited by heze; 01-23-2019 at 11:08 AM.. |
01-23-2019, 12:09 PM | #19 |
529
Rep 2,503
Ok, the few times I've seen that error (ecu conditions not correct) has been to do with supply voltage to the ECU.
Confirm you are coding with ignition on engine off? Also, can you check the fuses? For e70 I think it's 12 and 51???? |
01-23-2019, 01:29 PM | #20 | |
25
Rep 58
Ignition = on and engine = off Checking the fuses was a good idea: The DSC gets power from 3 locations F40, F46, F19. Unfortunanetely these are all good (measured on connector of DSC while in circuit, so also no resistance in the wires). Also both ground wires seems ok. Very strange that I'm the only one with this problem. Ideas are still welcome! Thanks all for trying helping me out! Best regards Hendrik |
01-23-2019, 01:37 PM | #21 | ||
529
Rep 2,503
01-23-2019, 02:08 PM | #22 | |
25
Rep 58
