Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Remove warning signs on dashboard
      01-18-2019, 01:05 PM   #1
Ken121306
Drives: E92
Does anyone knows how to possibly remove all the warning signs on the dashboard when my I drive is broken. Usually i know that people reset it by the idrive but mine is broken. What should i do?
      01-18-2019, 01:43 PM   #2
CircularMotion
14
Drives: New to the e90!
Pretty hard to give you an answer until we know what codes you may have.
Generally carly can clear most codes, or you can program certain things out. As for FRM stuff, you will need tool32 or some other instance.
Getting back to my roots!
      01-19-2019, 07:00 AM   #3
Ken121306
Drives: E92
I got CC-ID 63 code on the dash board but the problem has solved. So do u know if i can do anything to reset it?
Thanks
      01-27-2019, 08:01 AM   #4
Joe@TopGearSolutions
Joe@TopGearSolutions's Avatar
263
Drives: BMW
Thanks
Sounds like your TPMS is detecting a bad sensor or your tire is going flat?
      01-29-2019, 05:19 PM   #5
dpaul
654
Drives: 2009 E90 335xi, 2011 E93 M3
Nothing wrong with anything. Presume you needed air in a tire.
Add air. With the car stationary, use the stalk to get to 'check control', scroll to the flat tire icon and it will say "reset" underneath, Tap once, then tap and hold until the box and check appear. That resets it. (I think)
      02-21-2019, 07:03 PM   #6
cozytapescole
Drives: 2009 BMW E92 328i
Like Joe said. But, keep in mind it isn't uncommon for things like tire pressure sensors to go out.
