Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > [FIXED] FS Tool 2 Problem
      01-12-2019, 10:38 AM   #1
derDeno
Drives: e92 325i
Hey guys,
I retrofited the CIC into my 2007 e92 and flashed to the latest i-level.
I used the SWT Patcher v2 to virginize the CIC Certificates.
I edited the FSCs that where provided with the Patcher using FS Tool 2 to my cars vin.
But I have now a problem: first of all my CIC has still the vin of the donor car, i don't know how to change it, i think using FS Tool it self, but that leads to the second problem:
No matter what i try with FS Tool (i tried "get status", "check fsc", "get vin") i get the "car sever error 2020".
has anyone an idea why i get the 2020 error code and what does it means?
Regards
EDIT:
Fixed it by updating fs tool 2 and car server to the latest version i could find (2.20 / 19).
Now everything works as it should like
      01-12-2019, 12:24 PM   #2
derDeno
Drives: e92 325i
okay I actually got it to work, but new problem now: the cic only accepted the fsc for 17 but rejected the fsc and fsc cert for 1B and 19.
What am i doing from? i am doing the exact same step as i did for 17, but the fsc cert and fsc get everytime rejected? (error 2090)
      01-12-2019, 02:48 PM   #3
Sensible_
529
Drives: 2008 E90
Did you do:
StoreFSCSCert
CheckFSCSCert
StoreFSC
CheckFSC
For each certificate?
      01-13-2019, 08:21 AM   #4
derDeno
Drives: e92 325i
yes i did and get on every application number, except 17 and 9C, the error code 2090
      12-08-2020, 04:05 PM   #5
nisory23
Drives: bmw e36 m3, e63 630i, e92 330i
Hello,
I having the same issues with "get status", "check fsc", "get vin") i get the "car sever error 2020". I am unable to find a newer version of fstool, can you please help. thank you!
      07-26-2023, 10:17 AM   #6
greezy_goblin
greezy_goblin
greezy_goblin's Avatar
21
Drives: 2008 BMW 128i cabriolet
2008 BMW 335i  [0.00]
2008 BMW 128i  [5.00]
Originally Posted by derDeno View Post
Hey guys,
Regards
EDIT:
I'm having the same original issue of getting the 2020 error, can you provide a link to where I can get a newer version? much appreciated.
greezy_goblin
      08-08-2023, 11:36 AM   #7
redlineclipse
14
Drives: 07 335i
Did you ever find a working link for the latest FS Tools? I need it as well.
      08-08-2023, 11:44 AM   #8
greezy_goblin
greezy_goblin
21
No, sorry. I’ve taken a break from the project and still can’t find one, I’ll post it here if I do 👍
greezy_goblin
      08-18-2023, 05:32 PM   #9
F30__Blue
Drives: BMW F30
This installer should contain a working version of fstool, doesn't need to be latest to use just needs to work...
https://www.mediafire.com/file/1vra3....12.2.exe/file
Please press Appreciate button if I helped you
Tags
cic, fs tool, retrofit
