BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Launch control and wheelspin
      01-12-2019, 09:11 AM   #1
dk79
84
Drives: 2018 F90 M5 Marina bay blue
It's very frustrating, my car goes out of launch control very frequently especially with racechip. I am very jealous when you guys post 0 to 60 times of 2.7 sec with racechip.
I have tried different roads, diff rpms. Even on drag strip sometimes it does that.
Is there something wrong with my car? It happens with wheelspin or wheel hop when launching. I have stock 20 inch Michelin 4s tires.
I am pretty sure e63s does not do this.
      01-12-2019, 10:10 AM   #2
onfireX5
3619
Drives: F90M5,F85X5M
To get 2.7 , I have to time the pedal release perfectly or it’s spin city with RC. You will need a warm road, no sand on it and it helps if the tires are warmed up a few miles of driving. Then a 2600 rpm launch. Good luck !
      01-12-2019, 10:15 AM   #3
Miko M
///M
Miko M's Avatar
6654
Drives: 2020 M2C. 2020 X3M
+1
You can't wait to long, as soon as you see those flags you release the break, otherwise it will build boost and it will spin like crazy.
Practice buddy
I am going with wider and stickier tires
Life is too short...enjoy your life
///M
      01-12-2019, 11:10 AM   #4
marcvtec
407
Drives: M5
Try dropping the tire pressure to like 25 psi, that should help you get more grip
      01-12-2019, 02:29 PM   #5
r33_RGSport
General
r33_RGSport's Avatar
12971
Drives: G09 XM, G05 X5 40, 991.2 T
BMW LC is not the best, especially on this new chassis.
I couldn't get my G30 540 to do LC with RaceChip.
The rear wheel will spin off traction before the LC.
It was much easier on my previous, F15 X5 and F06 650GC.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      01-12-2019, 03:57 PM   #6
dk79
84
I going to track tonight will keep pressure around 28psi cold in all 4 and see what happens. Will either add race gas if pump has it or boostane to arizona 91 octane gas.
r33_RGSport12971.00
      01-12-2019, 04:01 PM   #7
Miko M
///M
Miko M's Avatar
6654
Good luck!
Lucky you, it's snowing here
///M
      01-12-2019, 04:51 PM   #8
r33_RGSport
General
12971
Bring tire gauge also to keep an eye on the hot tire pressure.
I am not too familiar in drag, but when I do track day, I try to maintain my tires around 32-34 hot.
      01-12-2019, 08:04 PM   #9
LongBeachDinanFan
286
Drives: M3
The JB4 can set boost by engine speed and gear so maybe that is part of the difference. There is only so much you can do with two connection points to the engine.
      01-13-2019, 01:51 AM   #10
dk79
84
Today was 1/8 mile unprepped surface racing.
Best was 7.4 sec 1/8 mile. Dragy reported best 0 to 60 3.4 sec. Also was using race gas 5 gallons 100 octane added to about 1/2 tank. Race chip set at race mode. 0 to 60ft did not improve more than 1.8 sec.
Man something is wrong with my car, others can do better even stock.
r33_RGSport12971.00
      01-13-2019, 08:05 AM   #11
Ever34
325
Drives: F90 M5
Out of curiosity what were your Dragy results stock?
      01-13-2019, 09:42 AM   #12
r33_RGSport
General
12971
onfireX5 and Miko M maybe can give you some pointer on the tricks.
Maybe you can give us the details on how you run the car.
Such as, launch RPM, driving mode, shifter mode, traction control mode, etc.
Miko M6653.50
      01-13-2019, 09:56 AM   #13
dk79
84
Stock is only 0.2 to 0.3 sec slower without racechip.
Last evening 0 to 60 was about the same with racechip on or off.
Maybe the race gas was fake. Next time will use boostane only.
      01-13-2019, 09:57 AM   #14
dk79
84
My m2 button is all set for launch control everything in sport plus and shifter in manual.
I let it go as soon as the flag comes.
      01-13-2019, 11:28 AM   #15
Miko M
///M
Miko M's Avatar
6654
I didn't have much time to run many pulls with performance tires before I switched to winter tires.
What is your altitude,temperature, humidity in your area?
Most important is the traction.
Obviously more spin more lost time.
You need to WARM up those tires for better traction!
Here are some numbers I got 0-60 on winter tires with RC
///M
r33_RGSport12971.00
      01-14-2019, 04:20 AM   #16
bpma
No_Country
155
Drives: M5C Stage 2
What app is that?
      01-14-2019, 05:29 AM   #17
Miko M
///M
Miko M's Avatar
6654
Originally Posted by bpma View Post
What app is that?
Dragy
You need to buy a dragy and download the app
///M
      01-14-2019, 07:37 PM   #18
MV99
38
Drives: 2018 E63 , 2018 M5, 2019 B7
Are you set full 4WD in M2 button? My M2 is set at sport plus on engine, transmission S3 and xDrive with DSC off with full 4WD not MDM to make sure max power loading on front wheel.
The attached dragy run was on map 6 (CA 91 octane) without early brake release for full rpm in LC. Road/tire temp is quite important. I ran most runs in Bay area near Tesla. The weather was near 70 for the run (a bit after noon time). I tried few times at night and got too much spin as temp were bellow 45.
I tried map 7 but it required early brake release for spin control. Less turbo boost made the time similar to map 6 full rpm. Replacing both rear tires soon and will try to see if that will allow full rpm LC under map 7?
      01-14-2019, 07:55 PM   #19
Miko M
///M
Miko M's Avatar
6654
Nice!
Mine was done at 40 deg. Lol
///M
      01-14-2019, 11:52 PM   #20
MV99
38
Originally Posted by Miko M View Post
Nice!
I used to live in Indiana, a beautiful place in winter. However, I don’t miss it that much if driving a F90 M5. With this big toy, 40 degree is good for little sliding fun with MDM 4WD or bigger excitement with 2WD if there is more room...... Hope you will enjoy the up coming spring!
      06-24-2019, 03:48 PM   #21
gtenedio
348
Drives: '%E2%80%9909 e92 m3, '19 X3, %
try suspension in comfort mode.
      07-27-2019, 08:51 AM   #22
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Continental DWS06 265/35-20 front 275/35-20 rear (32psi cold)
Launch Control in 70F 80% humidity
No Tune but has Full 3.5 Downpipes on Costco 93
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
m5post
