01-08-2019, 09:03 AM | #1 |
21
Rep 77
20” Tyre alternatives
After scouring the forum to gain some insights, I still hard hit with what to do and as much as there are posts with this subject...they tend to go off topic so maybe we need a fresh post!
Currently running on 20 inch 624m wheels on 225 35 and 255 30. I really HAVE to change away from runflats due to the harsh road noise so I am set on this decision completely. Forking our for 4 new tyres is most definetly not cheap and as much I would want the most expensive non-rft’s, I can’t warrant around £1k. I haven’t got a budget as such and yes I understand tyres are important blah blah blah but maybe some alternatives to the higher priced Pirelli’s etc. Maybe in between the £500-1000 for a full set. I’d seen good reviews on the Falken Azenis FK510 and after some digging I can source a new set for a smidge over £500. Any experiences and would be great to keep things ON TOPIC in this post |
01-08-2019, 09:55 AM | #3 | |
21
Rep 77
624’s are lightweight wheels, much lighter than the 442’s I had on previously. I’m looking at the index rating of different tyres and the p-zero’s I have on at the moment have a reading of 72db. For example the Falkens I have just mentioned really stand out as they have a reading of 69db. Also the other 2 ratings (fuel efficiency/rolling resistance and wet grip) are exactly the same as p-zeros. All in all...I’m going off statistics |
01-08-2019, 10:50 AM | #4 | |
6659
Rep 15,858
Really need experience of other users who have changed to specific tyre and can comment on the difference. |
Wills28657.50 |
01-08-2019, 10:59 AM | #5 |
606
Rep 1,455
When I replaced my Continentals (at the front only) which were 72dB I think, with Goodyears which were 69dB I can't say I really noticed any difference
As HighlandPete says the rating is not related to cabin noise |
10-19-2021, 10:41 AM | #6 |
Rep 3
Hi,
I have exactly the same dilemma right now, I have 624m 20" rims with Pirelli P zero runflats which hardly last and are not worth the money. Looking at fitting either Kumho PS71 or Falken FK510. Anyone any feedback on either of these? |
10-19-2021, 04:55 PM | #7 |
742
Rep 1,475
I found the reviews on here pretty useful:
https://www.tyrereviews.com/Tyre-Siz...5-20-Tyres.htm https://www.tyrereviews.com/Tyre-Siz...0-20-Tyres.htm I had a similar problem with Pirellis soft compound on my S2K, the rears were wearing away far too quickly. Opted for Hankook Ventus S12s which were pretty good all round tyres. Also worth checking for offers on Blackcircles.com or at Costco, tbey regularly have money off and can usually get MP4S. I got a full set of MP4S about 6 weeks ago (albeit for 19" wheels) recent for £540 fully fitted from Costco.
10-19-2021, 05:39 PM | #8 |
157
Rep 211
You have two concerns it seems - whether more budget tyres are going to perform and what tyres are going to be quieter. Cant help with the second one. My experience has been that big diameter low profile tyres tend to be noisy. I now spec smaller wheels (not tiny but certainly not the biggest possible). For your first concern - I have experience of the Falkens and thought they were very good. Not in any way inferior to premium that I could tell. One giveaway to me is how much balancing is required. Manufacturing tolerance of cheap tyres is sometimes such that they need a pile if weights in order to balance. Falkens were very good on that ‘test’
10-20-2021, 12:49 AM | #9 |
1388
Rep 2,128
The only non rft I have on my 624m as the MPS4S tyres so probably not very helpful to you. But, they are a bit quieter I can't really remember quite how much. The ride is noticeably smoother, however it's not smooth smooth, it's still a 20 inch tyre.
One thing I'm thinking about with mine though as that the fronts "look" perfect, but the rears look a little stretched. It's not much, but enough that I'm thinking a 265 would look better.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
10-20-2021, 04:23 AM | #10 |
The artist formerly known as AC Schnitzer UK
3610
Rep 4,518
As the OP's car is xDrive they need to be VERY careful about tyre swaps as many brands and models, even in the correct sizes, are not compatible with the xDrive system. Damage to the transfer case is the likely outcome if you use incompatible tyres.
We only recommend Michelin Pilot Sport 4S and Continental SportContact 6 in the standard sizes 225/35/20 and 255/30/20. They do not need to be star rated. AC Schnitzer have tested these and found them to be compatible with xDrive. We recommend the same tyres for RWD cars, but you are free to use others. Last edited by Lorcan; 10-20-2021 at 04:27 AM.. Reason: added detail |
10-20-2021, 05:42 AM | #11 | |
157
Rep 211
10-20-2021, 06:02 AM | #12 | |
3610
Rep 4,518
martin10chk157.00 HighlandPete6658.50 |
10-20-2021, 07:00 AM | #13 | |
6659
Rep 15,858
We can look at the tyre size guides, we read the nominal figures, having no knowledge of the tolerances used for a particular tyre. As an example, according to DIN 70020 at 37 mph (60 km/h), the nominal RC of our typical passenger car/SUV tyres can have a +1.5%/-2.5% tolerance. |
Lorcan3610.00 |
10-20-2021, 08:05 AM | #14 | |
3610
Rep 4,518
10-20-2021, 08:38 AM | #15 | |
6659
Rep 15,858
BTW, I understand the M5 transfer box has some design changes which adds to the cooling efficiency. |
10-20-2021, 10:19 AM | #16 |
157
Rep 211
So I read this as “don’t get an xDrive”. In any real world scenario the variation across tyres will trash the transfer box - I presume an expensive item. Seems pretty rubbish design to me to have a system that is so intolerant to expected natural variation!
10-20-2021, 10:44 AM | #17 | |
6659
Rep 15,858
Most users don't understand something like xDrive has engineering limits. Keep to approved tyres and the chance of faults and failures is minimal. |
martin10chk157.00 |
10-20-2021, 03:36 PM | #18 |
2259
Rep 2,048
And engines occasionally fail if you don't look after them, so don't get a car with an engine and instead cut a hole through the floor and go places Flintstone style. Yes, I'm being facetious but the reality is that if you want an effective 4wd system you're going to have limitations with tyres. Some setups are more fragile than others. The biggest downside of BMW's is the staggered wheel setup which you can't rotate to keep tyre wear even, but even then the reality is that driving style or the box just having a manufacturing weakness is as likely to give you a failure than the tyres being ever so slightly different in size.
