01-01-2019, 06:30 AM | #1 |
10
Rep 18
Head Unit Programming
Am I missing something, or can only 8 audio presets on any kind be made?
I would think that if I select CD I could save 8 CD's. If I select SAT, I would be able to select 8 different SAT channels. Same with AM/FM mode. For some reason, I can't seem to set slot 7 for a SAT channel. I have 1-6 & 8 set, but #7 isn't resetting. Strange. |
01-01-2019, 07:05 AM | #2 |
238
Rep 878
The buttons aren’t specifically for the media, you can set each to any function on the idrive, so for example I set no 8 on my car to bring up the tyre pressures/temperatures.
Guess you are limited to 8 but I have seen others use 1 of the buttons to switch user profiles which would then allow you 14 in total? |
01-01-2019, 07:39 PM | #3 |
32
Rep 79
I initially thought the same thing, but couldn’t believe it to be true, so I did some digging; here’s a good thread to show how various forum members have theirs programmed: 1-8 shortcut keys
I currently have mine setup as follows: 1: Navigate to (nearby) Home 2: Toggle split screen on/off 3: Activate presets/favorites - I currently have about 10 set - a combination of FM and SAT. I use the steering wheel scroll button to access these, and they all display on my instrument panel as I scroll. 4: Bring up screen brightness adjustment 5: Bring up audio settings 6: Display tire temps/pressures 7: Activate “mouse” on iDrive controller 8: End navigation There’s a myriad of ways to set these things up - you’ll be impressed once you figure it all out and configure yours. |
01-02-2019, 03:53 AM | #5 |
238
Rep 878
Yeah the Cd thing confused me too, what 8 things would you want to save when playing a CD?
01-02-2019, 11:14 AM | #6 |
99
Rep 148
01-02-2019, 02:01 PM | #7 |
Not stock
474
Rep 614
Prob old news, but I just learned that when you touch (don't push) the buttons, aka hover, it will show you the preset
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
01-02-2019, 03:20 PM | #8 |
238
Rep 878
If you’ve ever then tried to manage your imported media then you’ll probably realise that using a usb stick with music on it is so much easier to manage and update. I persevered with saving stuff the the hard drive but the very first time I wanted to add an extra song to an existing library I gave up 😀
01-03-2019, 03:59 PM | #9 |
Not stock
474
Rep 614
Is there any way to get more than 8 functions? For instance, is there like a "set 1" and "set 2" effect we can get? I'd like to save more than 8 presets. Thanks!
01-04-2019, 09:09 AM | #10 |
2025
Rep 2,805
Drives: F33 430 and F39 M35i
I don’t use mine that often
1 turn off display 2 sport displays 3 tpms 4 trip computer 5 ambient lighting I hate the hard drive for adding new music too. I ended up deleting everything and just using a usb stick. I can’t remember the last time I used a CD in the car. 2009?? |
01-04-2019, 07:03 PM | #11 | |
353
Rep 1,245
Not that I've ever seen. Remember - these are not audio presets per se. For example, my button 2 starts SXM and brings up the channel list. From there, I can use the favorites function and see all my favorites (FM/AM/SXM) You can also just load your music to a USB thumb drive. Or, best way, just stream it from your smartphone. (you can also listen to a ton of radio stations via TuneIn or IheartRadio |
01-04-2019, 07:08 PM | #12 | |
Not stock
474
Rep 614
But, I'd love to be able to set a few more... but alas I can't.
01-04-2019, 09:33 PM | #13 | |
171
Rep 257
For music selection, I just use the MODE button on the wheel and scroll through presets, HD FM, satellite, etc. But for CD's, I still use them. A lot. I am lucky enough to have a membership at alltunes com, owned by our friends the Russians, who steal and pirate everything, and the music is around 10 cents a song, or a buck or two for an album, so CD's come cheap. Plus CD's seem to make my H-K system come alive, more so than a USB stick, it seems to me.
2021 i3s AC Schnitzer BMW CCA #67486 |
