12-31-2018, 10:16 AM | #1 |
21
Rep 46
CPO Warranty...Question
Would there be any reason why a dealership would intentionally avoid finding/fixing problems that would be covered under the CPO warranty? Something didn't seem right with the dealer I had been going to and they weren't concerned about any of the issues I brought to their attention concerning oil consumption and defrost/heat issues. They just wanted to run non-covered diagnostic testing, telling me the oil consumption was within spec and most likely the findings would not be covered under the CPO warranty for the other issues. (they had the car in their possession for over a week, doing nothing but an inspection and oil change)
Not trusting them, I took the car to a good indipendent and within 2 minutes they pointed out a significant VCG leak causing the smoking and smell I'd been concerned about. Oil was also all over the front belt area and alternator, not just a little, a significant coating all over everything in the vicinity of the oil filter housing. I'm told it's another gasket failure that would most likely be causing other significant problems in the near future with the belts. Luckily I didn't accept the dealerships opinion that nothing was wrong. I can't figure out if they're incredibly incompetent, or if warranty work pays so poorly they wanted to pass? Either way I guess, no good. Not a good look for BMW of Reading. Dropped my car off at another dealer toady. It'll be interesting to see what they tell me. Thanks to everyone on the forum that's been a big help with my other questions in the past. |
12-31-2018, 10:36 AM | #2 |
35
Rep 96
I have been going to the same dealership for 17 years, but on a few occasions they have not fixed issues I would up getting corrected at another BMW dealer. I will also say that the CPO warranty is kind of a joke. I have a 2015 750i that BMWNA is “repurchasing” due to numerous issues I have had in the two months of ownership. None of the issues I had would have been covered by the CPO warranty. Luckily the car still had factory warranty.
Good luck and be persistent! |
12-31-2018, 10:57 AM | #3 |
806
Rep 1,906
This is interesting, can you list a sampling of the key issues you've experienced that were not covered?
What Dealerships do you deal with? Thanks/Bill |
12-31-2018, 10:59 AM | #4 |
21
Rep 46
Thanks. I've learned a great deal. Also, if I'm told the defrost/heat issue isn't covered I'll follow suit of another member on here that called BMW directly and got it covered. I'm tired of these companies hiding behind semantics and definitions of what is considered broken. i.e...clogged heater core
12-31-2018, 12:00 PM | #5 |
60
Rep 147
to OP, be sure to read both your CPO and SULEV coverage. CPO is silent on VCG, but might be eligible if linked to failure of other component that is covered. Also, PA is partial SULEV coverage state ....VCG included in full SULEV covered states, but not sure about partial SULEV states like PA (read the fine print)
12-31-2018, 12:13 PM | #6 |
Luxury at the redline :)
9105
Rep 7,563
The CPO coverage is not as comprehensive as the 4/50k factory warranty.
It's very limited it what it covers and it's harder for the dealer to get approval for repairs, as oppose to the factory coverage, which BMW AG basically just rubber-stamps. Hence the reason the dealer is reluctant to submit any 'ambiguous' claim or make any promises on its possible approval under any CPO or BMW Extended Coverage. It's not just BMW, all manufacture's CPO coverage is like this and it's the same nonsense with BMW Extended warranty; very limited coverage as CPO. I've learned this the hard way many years ago when my Acura warranty expired, the CPO kicked in and I realized it was just fluff to help push CPO vehicles, with a false sense of security My SA, whom I attended High School with confirmed this fact. She has to jump through many hoops to get stuff covered under BMW CPO or their extended warranty. #LiveAndLearn Last edited by Poochie; 12-31-2018 at 12:30 PM.. |
CalCarNut1060.50 |
12-31-2018, 02:19 PM | #7 |
21
Rep 46
I tried to read more on what's covered, but from the BMW site you just get a list of things that are not covered. Similar to the above. I'd think the failure of two gaskets significantly leaking oil would be considered a defect in the material? The CPO label seems to be a false sense of security. Looks like we as consumers would be better off catching a car off lease and putting the additional $2.5-4k premium for the CPO designation aside in a contingency fund. I'll keep the thread updated with what I hear from my SA. Thanks everyone
12-31-2018, 02:48 PM | #8 |
8243
Rep 16,082
Put it into a mutual fund and make money off your money, then make friends with a good indy shop that specializes in German cars. If you do your due diligence and see how many people actually make use of either CPO warranties or third party extended warranties you'll find that the percentage is quite low.
12-31-2018, 03:19 PM | #9 | |
1061
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
CPO is fluff marketing. Do NOT rely on this alone in purchasing a BMW (or any car). While it gives you some peace of mind for the initial year, it really doesn't cover much other than major failure of the drivetrain and you're certainly on your own after the year. The certification process is a joke as well. Any interest in a CPO car, take it to an Indy shop for a 2nd opinion ,etc and go from there. Could even tell them to take a hike on the CPO fee they build into the car for sale too
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
Poochie9104.50 |
12-31-2018, 03:44 PM | #10 |
Not stock
474
Rep 614
The difference to me is that I have a vehicle recognized by BMW NA (and its dealer network) as a CPO-approved vehicle. Sure, its not the same exact warranty as the original but that's also why it's not a new MSRP or similar retail priced car. It does, however, cover a lot more than a non-CPO car would w/o any warranty. So, it's splitting hairs IMHO. Personally, I wouldn't want to own a 2 - 3 year old BMW w/o a warranty - things are just too expensive and too technologically advanced at times to be repaired any old place. That's not to say I will dump my cars when they're out of CPO, but at that point they'll be... 6 - 7 years old and I can do the economics on replace vs. sustain.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
12-31-2018, 06:49 PM | #11 | ||
4488
Rep 10,473
As a result, they charge full price to the Underwriter for the repairs, so no, it’s not as if they get paid less so they would not not to repair. So incompetence is most likely. So which Dealer is so incompetent? Quote:
12-31-2018, 07:13 PM | #12 | |
9105
Rep 7,563
The company backing the CPO warranty doesn't care if you buy another BMW, so they have no vested interest if you're satisfied with the repair. Not trying to be a buzzkill just keeping it real. Google the subject if you're skeptical of my claim. |
12-31-2018, 07:23 PM | #13 | ||
Not stock
474
Rep 614
12-31-2018, 07:27 PM | #14 |
35
Rep 96
The CPO (CP No) would not cover my sunroof or suspension parts. Luckily I had the new car warranty in effect which also allowed me to file a lemon law claim. Frankly, when they make you sign the CPO warranty coverage disclaimer it’s a reminder BMW doesn’t want the issues of a used car either.
12-31-2018, 07:45 PM | #15 | |||
9105
Rep 7,563
However, when my transmission went out a year later, the warranty company sent someone to find reasons to deny any major claims. The adjuster was so full of shit based on nonsense he was blaming for the cause, that I flat out told him that and he didn't even deny it or get offended. I even explained to him that the rotors that he was blaming was made and approved by the vehicle manufacture. He stayed silent for a second then replied "Well, I'm still not going to cover it." It was like compromising with a stubborn 4 year old. I have no doubt they'll cover minor stuff but the minute anything substantial breaks, be prepared to change your outlook on CPO coverage. The dealer doesn't care either way, it's just another method for them to get paid. But it's in the hands of the warranty company to approve the claim, the dealer just submit the facts. After my experience, I did some research and confirmed this is the norm with CPO coverage, all fluff, no substance. |
12-31-2018, 08:56 PM | #17 |
4836
Rep 2,442
Drives: 2022 M3 6MT
Uhh, if I could, a lot of info stated on here is specific to personal experience.
First, the CPO Warrenty does not Cover: https://cpo.bmwusa.com/Content/docs/...NotCovered.pdf Looking through, it doesn't cover...normal wear and tear. If your engine goes, you'll be fine. Now, that being said, I can say that it really depends on where you buy the car. I've gone to dealers to see cars that were CPO that were a mess. I can honestly tell you my 328 with 120K was in better shape than a 335 I was in with 12K on it. Paint chipped and sprayed over, leather ripped, and an obviously rough engine. Only the best of the best should make it into the program, or have these issues fixed, but that often isn't the case. I've bought 2 CPO cars, a 335 and 528, that were pristine and ran excellent, from BMW of Ramsey. Upon purchasing the 335, they replaced all the brakes without hassle. My advice to anyone looking at a used BMW is this: do your research, and look at multiple cars at multiple dealers. Understand the real value of the car you're buying. And if the dealer gives you a hard time about repairs, bring it to another, or call NA. the concept that BMW does not care because it's a 4 year old car doesn't resonate with me. At the end of the day, if you're not happy, they want to try and fix it.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
01-01-2019, 11:41 AM | #18 | |
4488
Rep 10,473
01-01-2019, 12:09 PM | #19 | ||
4836
Rep 2,442
Drives: 2022 M3 6MT
N26Ghost496.50 |
01-01-2019, 12:20 PM | #20 | |||
4488
Rep 10,473
01-01-2019, 12:42 PM | #21 |
251
Rep 439
My thermostat started acting goofy with the computer at 76k miles. Not covered by the 7/70 extension from bmw. But covered by my cpo warranty. Phew. It was 2 years additional back then, now with 1 year only I would not opt to buy cpo from dealer. But yes, to everyone’s point. It’s just a third party extended warranty marketed by bmw to sell more used cars. Caveat emptor.
N26Ghost496.50 |
01-01-2019, 02:10 PM | #22 |
17
Rep 21
I had fairly good experience with 2 CPO cars I purchased, but they were about 10 years ago. The recent change of 1 year/unlimited CPO made it less desirable for me, which means it won't justify price difference more than $1K comparing to a similar non-CPO car.
You really have to analyze your own expected usage of the car until the CPO expiration date to decide whether you can get the most benefit out of the program. If you drives lot and project the mileage of the car to be close to or pass 100K miles in the last year of CPO coverage, it may be worth of the peaceful mind since more problems will likely to come out at higher mileage. But if you are looking at a mid-30K mile, 3 year old car (typical for a CPO with 3 year lease return), and you only drives 15K or less miles a year, your factory warranty will expire at 50K mile in a year, and the CPO only covers your car to 65K mile, I would not pay a premium on it. My recent purchase of a 2016 F36 was from a Toyota dealer. Even though it was not a CPO, the dealer performed thorough inspections, put 4 new tires on it, fixed all the wheels, paint chips and even repaint the front bumper. Brakes are at 8 and 9 mm. So that car is pretty much up to CPO spec, just without the extended 1 year warranty. And similar CPO cars are all asking 5-6K more, which is totally not worth of it. |
CalCarNut1060.50 |
