BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    JB4 and BMS stage 1. vs. RACECHIP. F90M5
      12-29-2018, 12:42 PM   #1
Steeve19M5CP
194
Drives: 2019 MBB Blue M5 Competition
Anyone can compare these two?
Burger offers a 4psi boost with stage1 and easy install plus a JB4 with multiple boost options and maps with phone control
RC offers two products ...how many maps and boost levels?
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package
2013 Lamborghini Aventador-Pearl Green-Modified
2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified
2018 Range Rover Velar S-White
soooma1377.50
      12-29-2018, 12:52 PM   #2
Miko M
///M
Miko M's Avatar
6654
Drives: 2020 M2C. 2020 X3M
Burger offers a 4psi boost with stage1 and easy install plus a JB4 eith multiple boost options and maps with phone control
@r33_RGSport can give you more details
It's 3 stage, efficient/sport/race map 3/5/7
Map 7 gives you about 70HP
Picture is with app control
Life is too short...enjoy your life
///M
r33_RGSport12971.00
      12-29-2018, 01:02 PM   #3
r33_RGSport
General
r33_RGSport's Avatar
12971
Drives: G09 XM, G05 X5 40, 991.2 T
Thank you Miko M for the call.
RaceChip has RS and GTS Black. Both available with or without App function.
RaceChip RS only have 6 maps and less aggressive mapping.
RaceChip GTS Black have 7 maps and more aggressive than RaceChip RS.
With App function, the mapping is pre-assigned from the backend to each individual mode.
While without App function, you can choose your mapping manually from 0-7 or 0-6 on the RS model, with 5 as default in GTS Black and 4 as default on RS.
Boost gain wise, I don't remember on top of my head. But onfireX5 should be able to chime in. He did a few data logging on it.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      12-29-2018, 03:30 PM   #4
Steeve19M5CP
194
Yes would like to know the boost levels for each map on both rs and gts
Also how do you change manually without app?
      12-29-2018, 03:31 PM   #5
Steeve19M5CP
194
You recommend rs or gts?
      12-29-2018, 03:43 PM   #6
Miko M
///M
Miko M's Avatar
6654
I would do GTS
See picture below, there is + and - to toggle between efficient/sport/race
///M
Appreciate 2
r33_RGSport12971.00
M 4EVER191.00
      12-29-2018, 04:55 PM   #7
Steeve19M5CP
194
But without phone app you have to pop hood and toggle with unit?
      12-29-2018, 05:33 PM   #8
Miko M
///M
Miko M's Avatar
6654
Yes, most people keep it on most aggressive setting so they don't open the hood all the time.
I have small commute so it's most of the time on efficient mode or when I drive the kids.
When alone or want to have fun, just press a button on phone
///M
      12-29-2018, 06:08 PM   #9
GUNGASLOW
192
Drives: 2019 M5
Does it hurt anything if you just leave it at the most aggressive setting all the time and just use the gas pedal to control the power?
      12-29-2018, 06:18 PM   #10
onfireX5
3619
Drives: F90M5,F85X5M
No. I have 32,000 miles on my X5M with it locked on 7. 2500 miles on my F90 with it locked on 7. I max them, log to verify and forget it.
Depending on atmospheric conditions, a 3 to 4 psi boooooost in power.
r33_RGSport12971.00
      12-29-2018, 08:51 PM   #11
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
The BMS F90 Stage1 is the absolute best value in F90 tuning, installs in 30 seconds, drives as smooth as stock, and provides solid 50-60whp gains. Via the simple TMAP connections only so much performance can be added and the Stage1 maximizes that performance. No other Stage1 type product can make more power because there is only so much power to be made without EWG control and CANbus control like the JB4 offers.
      12-29-2018, 09:44 PM   #12
Steeve19M5CP
194
Stage1 bms is 4psi increase over the stock 20.5psi ? =24.5psi?
How much boost increase on each of the different RC modes and maps?
      12-29-2018, 10:01 PM   #13
onfireX5
3619
Boost on the BMW DME is not a hard set target. It gets complicated with predicted mass air flow, etc.
Pure stock is roughly 17-18psi depending on atmospheric conditions.
RC on 7 will add 3-4psi to that “roughly “. I’ve never tested any of the lower numbers so I do not know the drop.
r33_RGSport12971.00
      12-30-2018, 07:50 AM   #14
Steeve19M5CP
194
I've heard stock psi maxes out at 20.5 psi...maybe more on Comp
      12-30-2018, 07:55 AM   #15
onfireX5
3619
Post a log.
      01-03-2019, 06:55 AM   #16
soooma
///MD
soooma's Avatar
1378
Drives: M5 F90
Originally Posted by Miko M View Post
I would do GTS
Key Miko
I still don’t know why people keep saying a Tune is better when it A. avoids warranty B. Disables innate protection mechanisms?!
Is it just because if more power gains?! Or full control on DME?! Flash?! Remap?!
Have Audi S8 with APR Stage II and it is amazingly powerful and no issues, but there’s were some weird things! Like car at times when coming to a stop would be still downshifting from gear 2 to 1 in very awkward way that jolts the whole car!! Rare but annoying!!
Also What’s our there now for F90 M5 that’s like APR II for Audi?!
      01-03-2019, 07:47 AM   #17
Miko M
///M
Miko M's Avatar
6654
I would do GTS
Key Miko
Hey soooma,
I will be switching to DME tune because off things you can change like CEL light remova ( I need this because off down pipes that I will remove today ) you can remove cold start ( I will leave this on ) you can remove speed limiter and also Increased burble
Obviously also more HP which should be close to APR 2
DME You have:
Stage 1 100HP 100TQ
Stage 2 140HP 130TQ
///M
      01-03-2019, 07:49 AM   #18
soooma
///MD
soooma's Avatar
1378
Drives: M5 F90
I would do GTS
Key Miko
I still don't know why people keep saying a Tune is better when it A. avoids warranty B. Disables innate protection mechanisms?!
Have Audi S8 with APR Stage II and it is amazingly powerful and no issues, but there's were some weird things! Like car at times when coming to a stop would be still downshifting from gear 2 to 1 in very awkward way that jolts the whole car!! Rare but annoying!!
Also What's our there now for F90 M5 that's like APR II for Audi?!
Hey soooma,
DME You have:
Stage 1 100HP 100TQ
Stage 2 140HP 130TQ
Cool!
Yeah not going down that route unless planning to keep it and if history is any indication, I won't I will make do with Piggy but itching for a better sound as this Stock Exhaust sounds terrible
Life is too short even if you live to be a 100!!
As what really counts is the few moments we are really happy and excited!
-Kids, Family, Success, Career, Helping others stand on their feet (Paying back and sometimes forward), Travel, Seeking the truth, Reading, Hobbies eg ///Madness -
      01-03-2019, 07:51 AM   #19
Miko M
///M
Miko M's Avatar
6654
I would do GTS
Key Miko
Hey soooma,
DME You have:
Stage 1 100HP 100TQ
Stage 2 140HP 130TQ
Cool!
RC is the way to go for you
Yeah, stock sounds terrible dough, just wasn't for me .
Good luck!
///M
soooma1377.50
      01-03-2019, 08:40 AM   #20
Steeve19M5CP
194
Knowing how much boost PSI is increased for each map is critical for engine safety.....example if there is too much boost in some cases you need to run race fuel.......why doesnt anyone know how much PSI increase is set on the RC for each map?
with JB4 it is very clear see the first post for info;
https://www.n54tech.com/forums/showp...41&postcount=1
soooma1377.50
      01-03-2019, 09:36 AM   #21
soooma
///MD
soooma's Avatar
1378
Drives: M5 F90
Actually I would like now to hear from RC people a clear answer to this!
      01-03-2019, 09:40 AM   #22
r33_RGSport
General
12971
https://www.n54tech.com/forums/showp...38;postcount=1
I'll ask them.
soooma1377.50
m5post
