Inpa injector coding issue - help pleae
12-29-2018, 04:55 AM | #1 |
19
Rep 227
Hi all,
Trying to code an injector in MSD80, got a connection in inpa 5.0.6, select shift f9 to get into e90, engine, msd80 for n43 etc, f9 for systemdiagnosen but there is no injector program? and all the f1,f2 etc etc have no menus? Any ideas what’s wrong? Online suggested there should be a shift f4 option for injector programming? Cheers |
01-01-2019, 07:50 PM | #2 |
1911
Rep 13,104
https://bimmerprofs.com/diagnostics-inpa-part-1/
see part 4 near the end F9/Shift + F4. Offset and multiplicative corrections (coding data) of injectors. https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF Last edited by ctuna; 01-01-2019 at 07:58 PM.. |
01-01-2019, 11:30 PM | #3 | |
2697
Rep 4,031
The MSD80 DME is used in the twin turbo N54 engine models of E9x cars, and that engine has direct injection High-Pressure piezo-injectors which DO require Adaptation entries (coding) into DME when injectors are changed. Perhaps someone with an N54 or N55 can offer specific info, but Bentley describes the process of "coding" injectors or entering "tolerance range numbers" copied from the injector body BEFORE installation, and then entered into the DME in an Adaptation Procedure. If you are installing a new injector in a port injection system, AFAIK if has no such 6-digit "tolerance range numbers" on it, and there is NO provision for entering such numbers into DME "code." Just my understanding as the owner of an N52 which is normally-aspirated and has NO provision for injector "coding." Someone with N43 please provide proper "educated" information. George |
01-02-2019, 09:42 AM | #4 | |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
01-02-2019, 09:48 AM | #5 | |
Sua Sponte
1299
Rep 2,850
https://ipfs.io/ipfs/QmXoypizjW3WknF...i/BMW_N43.html
