12-29-2018, 02:12 AM | #1 |
33
Rep 115
I think my clutch is slipping?
Hi, I drive an F32 428i 6MT and when I shift it really quick the car just holds revs high but doesn't really accelerate. When I have it in gear and floor it the car pulls strong though, and if I just shift a tiny bit slower it pulls just fine. It's only when I shift very quickly, I think the clutch slips. Maybe I'm already on the gas before I am completely off the clutch? I'm not sure. I'm wondering if there's any BMW technology or system that may be causing this because other than when I shift quick, it shows absolutely no signs of a slipping clutch. Thanks in advance to anyone who might have some ideas!
12-29-2018, 03:51 AM | #2 | |
32
Rep 117
Drives: F30 328i 6MT/ E36 M3 5MT
Alpine White 12' F30 328i 6MT (SOLD) Injen CAI | Bootmod3 Stage 1 | VRSF 5' Intercooler| Mishimoto Catch Can | 335i M Performance Exhaust | H&R Super Sports | HRE FF01 w/Hankook Ventus Evo2 | M-Sport Retrofit |
Wires1645.50 |
12-29-2018, 06:41 AM | #3 |
477
Rep 797
Could be DSC interfering. Try DSC off mode (hold traction button in).
Could be the bastard CDV. Search here for CDV. Take it out of your slave cylinder, you won't regret it. Go up a hill put it in 4th and mat it around 2k RPM. If the revs fly up your clutch is out. If it stutters you have a misfire or a bad 02 sensor. |
12-29-2018, 11:06 AM | #4 |
981
Rep 1,560
If you try to engage the clutch when the engine is at excessive RPMs, BMWs will usually just spin on the clutch and not engage until the engine and clutch RPMs get closer to the same speed. Since you say you are trying to "shift very quickly", you may just be giving it gas before the clutch can start to engage.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
12-29-2018, 02:34 PM | #5 | |
518
Rep 891
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
12-29-2018, 04:14 PM | #6 |
33
Rep 115
Car pulls just fine, no jumps in rpm, just accelerates normally.
12-29-2018, 04:28 PM | #7 | |
33
Rep 115
12-29-2018, 04:55 PM | #8 | |
806
Rep 1,906
Good luck/Bill |
12-29-2018, 06:27 PM | #10 |
981
Rep 1,560
Yes, this is a thing. When releasing the clutch you should have the engine RPMs near to the clutch RPMs. If you have the engine RPMs quite a bit above the clutch RPMs, then the clutch will slip until they can get back to the same RPMs. Other issues could make this happen (as mentioned above), but the least costly is to first be sure you are not causing it by getting back on the gas sooner than you should be.
12-29-2018, 07:35 PM | #11 |
806
Rep 1,906
12-31-2018, 12:06 PM | #12 | |
1646
Rep 4,877
Syncros in the transmission take care of getting the engine and transmission speeds matched. |
12-31-2018, 05:16 PM | #13 | |
981
Rep 1,560
Also, the "syncros" don't have anything to do with the clutch or engine speed, they synchronize the gears when you are trying to put your car into a specific gear with the clutch depressed. Here is a more technical description - "A synchronizer, or "synchro," lets the collar and gear synchronize their speeds while they're already in contact but before the dog teeth engage.". Speed matching the engine and transmission is the driver's responsibility.
01-01-2019, 09:10 AM | #14 | |
1646
Rep 4,877
01-01-2019, 09:23 AM | #15 | |
981
Rep 1,560
