12-28-2018, 02:50 PM | #1 |
Rep 20
Battery discharging while stopped....
Getting this message on my sons N47.
Says "electrical devices were temporarily switched off". He had battery trouble and it finally died. Went and had a new battery put in and registered. Still getting this message. Voltmeter shows 12.3V after sitting for 24 hours. Shows 13.4 while idling. In Texas so it isn't too cold. No phone chargers or anything left plugged into any charge ports. Car is locked as soon as he exits which should put ECM to sleep. |
12-28-2018, 03:00 PM | #2 | |
6659
Rep 15,858
12-28-2018, 03:29 PM | #3 |
Rep 20
SportySpice204.00 |
12-28-2018, 03:49 PM | #6 |
6659
Rep 15,858
12-28-2018, 04:00 PM | #7 |
Rep 20
12-29-2018, 10:06 AM | #8 |
521
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
If I don't drive my car for more than a week I have to use the key fob to open instead of the comfort access... then I get the discharge notice... car still starts fine and battery is still holding charge...
12-29-2018, 02:47 PM | #9 |
¯\_(ツ)_/¯
537
Rep 1,000
It's when you have the comfy drivers seat so your ass is comfortable
12-29-2018, 04:46 PM | #10 |
516
Rep 1,452
How close do you have the key FOB? If it’s too close,that could be what’s causing some of the drain.
12-30-2018, 06:39 PM | #12 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Agree, would expect a higher charge rate. Was the registration done correctly, its what sets the initial charge rate? If you have Carly you can check & re-register it yourself.
Also if the system is shutting something down you need to find out what it is. Most likely the source of the drain if there is one. It might be shutting something down that is normally active because the battery is not being sufficiently charged. We have devices on the BMW that go to sleep with the lock but many are still drawing amps to keep their memory settings alive. FWIW my Cobra has been inactive for 3 months due to a house renovation dumpster blocking it in the garage. Car fired up on the first key turn without any outside battery support like a trickle charge etc. It has a ECU & entertainment system that stays hot, to preserve their memories, when the car is shut off. Its a low amp draw but still a draw.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 12-30-2018 at 06:55 PM.. |
12-31-2018, 11:58 AM | #13 |
1646
Rep 4,877
If you are seeing 12.3V after 24 hours, I wouldn't suspect a battery drain issue.
What if you disconnect the battery for 5 minutes, and re-connect? |
12-31-2018, 11:40 PM | #14 |
3129
Rep 5,264
A fully charged 12V battery should read around 13.2 volts straight off the charger & about 12.7 after 24 hours. At 12 volts its dead.
Cells in modern batteries are rated at 2.2 volts each, a 12 volt battery has 6 cells.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
01-01-2019, 11:00 AM | #15 |
772
Rep 1,502
I’ve never seen this on my 335i after it sits for a week, although I tend to use the fob more than comfort access to open the doors. Our X5 3.5i with the same N55 engine routinely sits for 2-3 weeks in the garage with no issues at all on startup, although it doesn’t have comfort access.
01-02-2019, 03:24 PM | #17 | |
521
Rep 1,288
01-02-2019, 03:41 PM | #18 | |
21
Rep 76
