12-28-2018, 02:07 PM | #1 |
2015 435i xdrive- 6spd, cp, dp, fmic, bm3 stage 2
25
Rep 41
435 Flywheel is exposed to the elements!?
Under my 435i 6speed the other day and noticed a cutout hole where my flywheel is. Indie mechanic said that's normal. But is it? I mean, what about dust/rain/moisture/debris. Wouldn't that destroy those critical metal components. Anyone notice this on their N55?
12-28-2018, 02:23 PM | #2 |
#gotboost
517
Rep 861
Is it where the starter is located?
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
12-28-2018, 02:28 PM | #3 |
1996
Rep 2,499
How large is the hole? I don't believe our cars have an access/inspection panel for the flywheel. But there probably are some small holes where you can see the flywheel. If it's just some small holes where you can see a couple teeth of the starter ring gear or something, it's probably normal.
12-28-2018, 02:36 PM | #4 |
25
Rep 41
It is located where the engine meets the trans, just back from the oil pan. The hole is facing downwards towards the road and is about the size of quarter. I saw teeth from a large round object and I'm assuming that's the flywheel. Just seemed very odd that it wouldn't be sealed from the elements
12-28-2018, 05:46 PM | #5 |
1996
Rep 2,499
It's pretty common for there to be little holes visible into the flywheel and clutch. Some older cable actuated clutches had little throwout forks that you could see the clutch assembly from in the bell housing.
A flywheel is really just like the brake disc and the clutch is like a brake pad. Brakes are far more exposed and you don't really have any issues with foreign objects in your brake system. |
12-29-2018, 11:03 AM | #6 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Agree its not an issue.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
