12-28-2018, 01:29 PM | #1 |
101
Rep 96
Drives: BMW X3 M40i
Bimmercode Question
I just got bimmercode.
When I open up the app there are many options to change. They are all pre-selected. For example, the default halo brightness says it is at 10%. (Is that default by bimmercode?) Let say I do not adjust that setting, but I adjust another setting in that category like "brake force display mode" and click "code". Will this change all of the settings in that category? So lets say my halos we at 50% previously, and even though I didn't change the halo category, because it was set at 10%, will my halos be coded to this new percentage? So do I need to know what all my settings were at previously? There is also a section called Rear Electronic Module. This section has voltage monitoring for every bulb. Some are LED, some are bulb, and some are not active. Same question as above. Are these standard? Do I need to know what every bulb is? If I click code, am I supposed to go through every setting in that section? Thanks!!
Previous:
2015 BMW 435xi M Sport Current: 2018 BMW X3 M40i |
12-28-2018, 01:34 PM | #2 |
497
Rep 537
Everything you see is what the current data shows in your ECUs. These are the values that came from the factory.
You are not required to select a new value for every option. Just the ones you intend to change and code.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
12-28-2018, 01:35 PM | #3 |
2465
Rep 5,457
Drives: F30
I believe that whatever setting is shown on BimmerCode currently... IS the factory setting.
If you change one parameter and click code... nothing will change except that specific parameter. Same for the bulbs. If you change any bulbs to LED from Halogen, you would need to change the setting in BimmerCode to prevent a fault (cold/warm checks). |
12-28-2018, 01:37 PM | #4 |
101
Rep 96
Drives: BMW X3 M40i
Got it thanks guys.
I just went into "demo" mode on the app and it defaults the angel eyes brightness to 12%. And when I am connected to the car, it says 10%, so that all makes sense. Thanks!
Previous:
