12-27-2018, 03:38 PM | #1 |
132
Rep 282
Anyone have this steering cover? (Stitching)
there is 2 different kinds but does any of you have something like this? if so, does it effect the heated steering wheel feature? does it take longer to warm up or it's not that warm as before?
Thanks https://rover.ebay.com/rover/0/0/0?m...2F323179565724 https://rover.ebay.com/rover/0/0/0?m...2F222819290377 |
12-27-2018, 03:45 PM | #2 |
18705
Rep 14,115
Drives: G82 M4C X-Drive
Good thing they censored the emblem.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
Dreamvillainz132.00 |
12-27-2018, 05:26 PM | #3 |
8243
Rep 16,082
12-27-2018, 07:26 PM | #4 | |
202
Rep 533
435i GC
12-27-2018, 08:24 PM | #5 | ||
132
Rep 282
12-28-2018, 12:58 AM | #7 |
18705
Rep 14,115
They look really nice but the final result is most probably directly proportional to the buyer's sewing skills. So in my case it will look ass.
IraHayes154.00 |
12-28-2018, 08:35 AM | #9 |
66
Rep 204
Drives: 2016 428i GC Alpine White
I wonder if they have received warnings from BMW IP lawyers?
2016 428i GC
12-28-2018, 01:48 PM | #10 |
No 55mph
1622
Rep 8,476
If you removed the original OEM covering & replaced it with these the heat rate/output would be the same
If you add this cover on top of your factory covering it would definitely take longer to heat + would prolly not look good with so many layers and stitching on top of stitching Version with Alcantara sections may not hold up under heating function - there is a reason BMW does not have heating function available on ANY of it's wheels with Alcantara - I'm guessing alcantara + heat = don't play well
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
12-28-2018, 03:19 PM | #11 |
4516
Rep 8,942
Coby will do whatever kind of alcantara wrap you want - professional job for ~$200 if memory serves. More than DIY but no chance of getting annoyed or doing a shit job and wasting the money.
https://www.cobywheel.com
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
12-28-2018, 04:17 PM | #12 |
8243
Rep 16,082
If you do it won't fit, being sized to go over the original covering. It warns against that in the instructions, and when you put one on you can see why. I found it necessary to remove the original covering in the wells that the switches fit into, but otherwise left the original cover untouched.
12-28-2018, 10:37 PM | #13 |
41
Rep 91
If it helps at all, I did get a Coby alcantara wheel earlier this year, and now that the weather has cooled down, I can say that the heating function is definitely retained (and quite effective). I have been very happy with the material and stitching quality, and I feel confident that it was worth the price premium over a DIY option.
--Jeff |
12-28-2018, 10:45 PM | #14 | |
2000
Rep 3,680
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
