12-27-2018, 12:19 PM | #1 |
Rep 15
Key Fob Battery ..
Hi,
can anyone shed some Light on Why , my 4 Series F36 Key Fob after changing the battery inside , its still showing up on dash , Replace Battery.. Do i need to Sync or something ? Regards |
12-27-2018, 01:12 PM | #2 |
79
Rep 270
mine automatically went away (I think after I turned on the car) . do you have a multimeter to test the battery? maybe it was just a bad battery you had for replacement
2013 328i xDrive | M Performance Exhaust | Injen Intake | DEPO Headlights |
2019 440i xDrive | Muffler Delete | |
12-27-2018, 02:26 PM | #4 |
Rep 15
Thanks For Replies ...
Battery put in was a New 1 ... and when symbol is on, i do put the fob to steering wheel and it does disappear but when unlock car again, its back .... |
12-27-2018, 03:10 PM | #6 |
839
Rep 440
Drives: 2013 335i xDrive
Mine did that until I replaced batteries in both remotes.
I'm not completely useless, I can be used as a bad example.
12-28-2018, 10:32 AM | #7 |
353
Rep 1,245
Yeah - be sure you change both remotes. And ensure the battery is good.
Mine went out when I was out of town. Stopped by a BMW dealer in Charlottesville, VA, and they changed the batteries for me - cost about $30. |
12-28-2018, 01:19 PM | #8 |
100
Rep 215
Did both fobs have empty batteries? In my case, only one of them had and replacing it solved the problem. I didn't do anything extra, the car recognized the fob and the warning went away.
12-29-2018, 01:58 AM | #10 |
1508
Rep 1,387
Had the same thing happen just before Christmas. Changed battery in offending fob, then held it up to the spot on the column and pressed the start button WITHOUT my foot on the brake so the car did not start. This seems to clear the alert. I made sure that the other remote was well clear during this procedure.
12-29-2018, 03:52 AM | #11 |
2963
Rep 5,997
Not sure if free maintenance (old or new) includes key fob battery replacement? So far haven't had to replace mine though I know these newer comfort access/start button key fob batteries drain faster than the old non bi directional communication key fobs do.
12-29-2018, 08:50 AM | #12 |
81
Rep 552
The batteries don't cost more than a few dollars and are very easy to change.
12-29-2018, 09:11 AM | #13 |
29
Rep 165
Yes it does. I took my 2017 440i convertible in for scheduled maintenance (2nd one) and one of the things performed was a replacement of the battery in the key fob. Wish I was smart enough to remember to bring the second key fob with me and have its battery replaced, but I'm not that smart. Next time I bring car in I will take second key fob with me and have them change that one also.
bimmer4562962.50 |
12-29-2018, 09:56 AM | #14 | |
2963
Rep 5,997
12-30-2018, 10:08 AM | #15 |
353
Rep 1,245
Yeah - they're very easy to change. But when you're out of town, a BMW dealer is 2 miles away, and they'll do it for you start-to-finish in under 5 minutes, I went that route.
Trust me, I'm frugal, but there are some times that call for spending on convenience. |
12-30-2018, 10:25 AM | #16 | ||
29
Rep 165
12-30-2018, 10:26 AM | #17 | |
2963
Rep 5,997
12-30-2018, 10:32 AM | #18 | ||
29
Rep 165
12-30-2018, 10:33 AM | #19 | |||
2963
Rep 5,997
