12-27-2018, 09:08 AM | #1 |
Rep 2
BMW alarm installation
Hi,
I recently purchased a used BMW 428i xdrive and noticed after I took it home that the car doesn't make a beep sound when I lock it. Normally I've seen the light under the mirror flash red in most BMW's but mine doesn't. Any ideas? Thank you., Nick |
12-27-2018, 09:14 AM | #3 | |
2465
Rep 5,457
Drives: F30
Looking into the retrofit but not sure how expensive or involved the DIY would be... Anyone with insight, please share. |
12-27-2018, 09:25 AM | #4 |
Rep 2
Got it, thanks. On getbmwparts.com, I searched alarm and it came to the Inclination Sensor - BMW (65-75-9-493-759). Is this all that is needed to install the alarm or is there more?
12-27-2018, 09:29 AM | #5 |
54
Rep 202
Drives: 2011 M3 6sp
No there is more required I'm currently doing this retrofit, it requires the alarm bell and mount, a new roof function center (the thing with the lights above you near the driver seat in the middle on the headliner), and you have to run a cable from this new roof control center at the front of the car to the back of the car to the alarm bell which you will install in a space located above the wheel well liner on the left side. Theres is a diy here if you use the search and it should be a top post by roxxor. The install itself was not hard at all and sifting through eBay I was able to get everything for around 125$
sspade2464.50 |
12-27-2018, 09:39 AM | #6 | |
2465
Rep 5,457
Drives: F30
The running of the cable from front to rear seems like the only challenge. Any coding involved? |
12-27-2018, 09:43 AM | #7 | ||
54
Rep 202
Drives: 2011 M3 6sp
12-30-2018, 01:34 PM | #8 | ||
54
Rep 202
Drives: 2011 M3 6sp
12-31-2018, 12:00 PM | #11 |
1996
Rep 2,499
So if there's no alarm, the car will not beep when you lock it? I thought all BMWs make the same lock tone that has nothing to do with the alarm.
Have you checked the lock settings in iDrive? There is a setting to enable/disable the lock sounds from there. |
12-31-2018, 01:41 PM | #12 |
238
Rep 878
I had to enable the option for audible arming/disarming via coding after which I got an option in idrive.
