12-26-2018, 01:39 PM | #1 |
57
Rep 76
Steering rack replacement issues on tuned car?
I have a 2014 328D with a Mission Performance Stage 2 tune. Got into an accident last month that messed up the suspension."Bent the front and rear rim on the driver side, bent the front strut, front wheel bearing and hub replaced" The collision center is owned by the BMW dealership, and they fixed the the damage but the steering rack started giving me issues after I picked it up so I scheduled to bring it back so they could replace the rack. Well in-between picking it up and bringing it back to them I had it tuned and removed all the modules for the diesel emissions."DEF tank, NOX modules, SCR, DPF, and EGR turned off" Brought it back this morning, and they swapped out the rack this morning but are having issues programming it. They said the traction control is turned off and it will not let them program the steering rack because of the program they are using talks to all the computers in the car. Talked to Alex at MP and he said the tune has nothing to do with the computer for the steering rack, that it's something they are doing wrong. Also checked with a local indy shop and explained the situation. They weren't 100% but seemed to side with MP about the tune not affecting the steering rack. Was curious if anyone else on here has a tune and had issues with BMW being able to code new parts? Seems like the techs are using the tune as an excuse for not being able to code the car according to MP. Update collision center is using ISTA so not their fault, the tune is causing the problem.
12-26-2018, 01:51 PM | #2 |
806
Rep 1,906
somewhat related (?),read here: https://f30.bimmerpost.com/forums/sh....php?t=1566880
12-26-2018, 02:03 PM | #3 | ||
4488
Rep 10,473
A lot of words in that post but not a lot of specific details. This I know is fact. BMW Dealers connect cars to ISTA. It then looks at what’s suppose to be be on the vehicle from the BMW Database. If any of those ECUs etc do not match up or report being in a state that isn’t normal, it throws an error and stops the process. For example, you can put a F80 shifter in a F30 and it will function. You can also put a normal 5 series shifter in a F30 (won’t physically fit but it will function). However, once ISTA polls those ECUs and realizes they are not the right ones, it will terminate the procedure with an error report. Clearly, something MP did (or you pulling off parts) is throwing errors in ISTA and is not letting the car be programmed by ISTA. The ECUs can usually be programmed individually with esys, but Dealers do not use that. ISTA takes all the steps and does it automatically. This is a known issue when you start modifying a car. Quote:
jmg18705.00 |
12-26-2018, 02:04 PM | #4 |
238
Rep 878
If the tune has coded extra stuff that isn’t part of your vin then that might explain why they are having difficulties. When I had my steering rack replaced the dealer rang me to say they’d need to keep the car for an extra day as they needed to update the car in order to get the new rack working. If the bmw update process uses the vin then maybe anything unexpected causes an issue?
The above are just just my thoughts and not fact by the way. |
12-26-2018, 02:18 PM | #5 | ||
18705
Rep 14,115
Drives: G82 M4C X-Drive
100% correct. I would reflash to stock and see if the dealer can re-program.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
12-26-2018, 02:29 PM | #6 | |
57
Rep 76
01-24-2019, 02:00 PM | #8 |
806
Rep 1,906
