Having difficulty setting up my ISTA P
12-25-2018, 06:50 PM | #1 |
2657
Rep 6,290
I've obtained ISTA D and ISTA P as a package type thing and my ISTA D is running perfectly well.
My issue is with ISTA P. To launch ISTA P I use ISTA P loader and choose the K+DCAN ICOM Emulator and then BMW. Then when I try to launch a session I get error "No ISTA/P server on whioch a session can be started was found. Try again later". If I go in manual session I see my PC name and the red X disabled. I'm not sure if I should be seeing any ICOM pop up in iTool Radar, but ther isn't any even whedn the ICOM Emulator is run. I've only found one related thread online and the issue ended up being the user's faulty ICOM cable. But I'm using K+DCAN and it works fine with ISTA D. So I'm really at an end here. The user guide I have to installed the software I follow until along until I hit the iTool radar part where even with the emulator run my ICOM don't show up. Yeah, if anyone knows what I'm talking about or using these software any help appreciated. |
12-25-2018, 06:58 PM | #2 | |
529
Rep 2,503
12-25-2018, 07:09 PM | #3 |
2657
Rep 6,290
I wanted ISTA P as it was my understanding it is much better since it does everything you could need in terms of coding and it has a easy to use GUI.
12-25-2018, 07:38 PM | #4 | |
529
Rep 2,503
Winkfp and NCS is far more versatile. ISTA P with K+DCAN is a waste of time in my opinion. If you insist on ISTA P with the ISTA loader the K+DCAN cable should appear in connection manager as an emulated ICOM. |
12-25-2018, 07:43 PM | #5 | |
2657
Rep 6,290
Yeah I would still like to get ISTA P going since I'm sure my issue is something small. And already have all the data transferred. Sorry by connection manager, you mean somewhere under ISTA P or in iTool Radar? Last edited by TheMidnightNarwhal; 12-25-2018 at 07:52 PM.. |
12-25-2018, 08:04 PM | #6 | ||
529
Rep 2,503
Anyway, this is a very good guide. Watch it and double check your setup. |
12-25-2018, 08:24 PM | #7 | |
2657
Rep 6,290
I've watched the video before. Took another watch and it still gives me same error. I hadn't enabled my USB network adapter so I thought that would have been it but nada. |
12-25-2018, 08:47 PM | #8 | ||
529
Rep 2,503
For new generations (F, G, I) there is Esys. ISTA+ would be the dealer equivalent. Anyway, apply the ISTA P fix and it should work: https://drive.google.com/file/d/1YJN...w?usp=drivesdk |
12-25-2018, 09:28 PM | #9 | |
2657
Rep 6,290
My WSM folder was also empty. I got the software package from a post in the F series and can't find that post anymore but it was extremely popular. No one mentioned issue with ISTA P. |
12-25-2018, 09:36 PM | #10 | ||
529
Rep 2,503
Hope ISTA-P goes well for you. |
12-25-2018, 09:45 PM | #11 |
2657
Rep 6,290
12-26-2018, 12:32 AM | #12 | |
529
Rep 2,503
12-26-2018, 12:35 AM | #13 |
2657
Rep 6,290
12-26-2018, 01:42 AM | #14 |
1911
Rep 13,104
https://www.bimmerforums.com/forum/s...-P-actually-do
Some comment on ista p in the above link. Its has been described here is as and all or nothing program for updating the entire car or for module replacement programing at the dealership. Precautions like using a large power supply attached while programming and using the icom cable seem to be mandatory. I don't know if later versions over come some of these problems or not. The Inpa suite is actually a BMW Engineering Tool used to manipulate things on a very direct and basic level yet still have an interface that some humans can understand. Mostly German Humans. |
12-26-2018, 08:59 PM | #15 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
ISTA/P is overkill for just about anything you'll ever want or need to do on a E series. Have a F or G series, I can see the need then. Hell, in the time it takes to download and install ISTA/P, you can download Standard Tools with daten, install it, and completely code a car and probably update any modules as well.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
06-16-2019, 01:34 PM | #16 |
Rep 23
I installed ISTA-P 3.65.2 and I'm getting a parsing error when launching
C: Windows\Microsoft.net\Framework\v2.0.50727\config\ machine.config Parse returned error 0xC00CE556 Any help would be really appreciated. I'm a total newbie at this but I have learned tons in the past 3 days trying to do this. |
06-16-2019, 08:22 PM | #17 |
1911
Rep 13,104
when you get a method or parsing error I would look
at the Microsoft C++ programs and make sure you have all of them instaled. Go to Microsoft to find the full install. Also I believe your suppose to have netframework 4.7 or above. |
