12-23-2018, 12:06 PM | #2 | |
54
Rep 202
Drives: 2011 M3 6sp
Someone else chime in but I do believe you've got to vo code it Search shall be your friend : https://www.bimmerpost.com/forums/sh...php?p=12038371 |
12-23-2018, 03:32 PM | #3 | ||
54
Rep 202
Drives: 2011 M3 6sp
12-25-2018, 01:22 PM | #4 |
54
Rep 202
Drives: 2011 M3 6sp
12-25-2018, 06:47 PM | #5 |
516
Rep 1,452
This is fascinating. I have no idea what you folks are talking about. I know how to check the oil. Especially since you don’t have to raise the hood to do it.
12-26-2018, 02:04 AM | #6 | |
54
Rep 202
Drives: 2011 M3 6sp
12-26-2018, 02:06 AM | #7 |
54
Rep 202
Drives: 2011 M3 6sp
hey no biggie honestly I didn't know jack until I did my first mod then I started getting addicted and just like learning more about my car when money permits LOL this isn't half as bad as when I was virginizing a used instrument cluster to put in my car, but honestly I just started at the diy coding thread and reading tons from people here
12-30-2018, 05:32 PM | #8 | |
Rep 3
I am a bit lost on this step Read SVT (VCM) Does VCM mean that I have to read the SVT on the Expert mode => VCM tag or in Codding tag? Since both have READ SVT bottom. Then I don't want to mess up this so I will write what steps I will be following. Can you check them for me, please? Connect => Read FA (VO) => Save FA (VO)(just in case) => Activate FA (VO) => Read SVT (VCM) Here are two possibilities: 1 CADF are not corrupted so I will follow => Right*Click on ICM (the ECU itself not the underlying CAFD) => Select CODE. 2CADF ARE corrupted =>Left-Click ICM option within Coding or VCM?=> Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level displayed => Select OK => Right-Click on ICM (the ECU itself not the underlying CAFD) => Select CODE. Thanks for your help |
12-30-2018, 05:34 PM | #9 |
54
Rep 202
Drives: 2011 M3 6sp
For all of this you should be in the coding part of the expert tab
12-31-2018, 03:31 PM | #10 |
54
Rep 202
Drives: 2011 M3 6sp
Possibly, what do you mean you lost start stop? And did you have anything coded prior to the icm you had before?
04-19-2020, 11:06 PM | #11 | |
Rep 48
icm.
stay healthy
