12-22-2018, 08:15 AM | #1 |
326
Rep 535
Things that makes you go hmmm
So one of my 19 wheels cracked, sucks. Took them off and put the stock 18 stuff and immediately noticed that the transmission started shifting smoothly again. With the 19s 1st to 2nd and sometimes to 3rd the transition was super harsh. Anyone out there noticed something similar?
'17 C7 Vette GS (bye) / '15 F31 328 ix (sold) / '08 E92 335i (sold)/ '08 E92 M3 (RIP)/'01 M5 (sold, sniff)/'07 M5 (sold)/ '15 M5
12-22-2018, 12:32 PM | #2 |
¯\_(ツ)_/¯
537
Rep 1,000
What kind of 19s did you have. Maybe theyre just too heavy
12-22-2018, 01:03 PM | #3 |
326
Rep 535
Some Zito wheels, not the heaviest out there, didn't think that weight would affect the trans. shifting , not sure how much they weight though.
12-22-2018, 01:09 PM | #4 |
Cheapskate
4450
Rep 4,993
Bigger wheels put a bigger load on the transmission. Partially because you increase the overall weight, mostly because you shift the majority of the weight farther from the center of the hub (think like a pendulum). But ultimately 19s shouldn't make that much of a difference. Especially considering OEM 19s are like concrete bricks.
12-22-2018, 01:11 PM | #5 | |
326
Rep 535
Blubaron791434.50 kern4174449.50 |
12-22-2018, 02:24 PM | #7 |
326
Rep 535
No warranty. I thought there was a way for us to reset the adaptations ourselves,
12-22-2018, 02:30 PM | #8 | |
6659
Rep 15,858
12-22-2018, 02:37 PM | #9 |
326
Rep 535
Yes, 328 Xdrive, tire sizes 235/35-19 and 265/30-19
12-22-2018, 03:27 PM | #10 |
6659
Rep 15,858
Probably transmission isn't accommodating the bigger difference in RC than OE sizing. If treads depths are different, front to rear, could be making it even worse. Showing up in bad changes.
18" wheels, are tires OE sizes? |
12-22-2018, 05:41 PM | #11 |
326
Rep 535
Yes, OE sizes 225 squared.
12-23-2018, 02:53 AM | #12 |
6659
Rep 15,858
I'd wager your gearbox harshness is due to the tires pushing the tolerance limits for the xDrive system. Transmission now back in tolerance on EO sized tires. You won't be the first or last to suffer some sort of transmission issues due to the wrong tire tolerances.
12-23-2018, 03:12 AM | #13 |
2JZ-GTE
3042
Rep 3,996
Love the title of this thread.
ricardofors68325.50 |
12-23-2018, 03:00 PM | #14 |
101
Rep 337
I have 20's on my F36 and no such issue here, and that's coming from an F31 with 18's.
Of course the bigger wheels do add strain to the transmission as they effectively 'gear up' the entire transmission. But if you noticed issues with the larger wheels, it could well be an early indicator of a transmission problem. Or it could also be that BMW altered the transmission program to match the wheels originally fitted to the car. That would also make a great deal of sense as it would mean that all cars offered the smoothest experience, regardless of wheel options. Might be well worth just calling BMW care and asking. |
12-24-2018, 06:02 AM | #15 |
6659
Rep 15,858
It's the last thing many would want to do, knowing the car is not on an OE tire combination for 20" wheels.
I'm sure they will ask if the tires are OE sizes and BMW star marked. Particularly as it is xDrive, with the customer raising a suspected transmission issue. |
12-24-2018, 06:05 AM | #16 |
6659
Rep 15,858
01-09-2019, 06:41 PM | #18 |
326
Rep 535
Seems so, if so, I guess I would have to pay attention to tire diameter if I want to keep the 19in hoops
01-09-2019, 09:04 PM | #19 |
1599
Rep 3,748
01-10-2019, 03:18 AM | #20 |
2963
Rep 5,997
X drive can have issues when using aftermarket rims. You will need to make sure your total wheel and tire diameter is the same as stock for your vehicle or it will act up, especially if you have a staggered setup. I think it has to be square.
01-10-2019, 01:01 PM | #21 |
18705
Rep 14,115
Drives: G82 M4C X-Drive
It seems like this discussion comes up every few years and each time it usually goes something like this:
1) Someone wants to run staggered on an AWD setup. 2) Someone else tells them they should run square because it will put strain on the drivetrain. 3) Someone argues that the change is within tolerances. 4) We choose to believe that it is within tolerances because it looks cooler. Rise. repeat. I said this 18 years ago when I was driving an Audi A4 Quattro: Run squared. That's what the system was designed for. Rise. repeat.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
