2007 E90 Bootlid Issue
12-19-2018, 03:39 PM | #1 |
Rep 2
Hi,
I'm looking for some help if possible. i have a 2007 E90 saloon. The other day i shut my boot like normal but once in the car saw that the "boot open" warning light came up. I went to investigate, I lifted the boot and there was no assistance at all. I had to lift the full weight of the bootlid- i get this may be issue with the struts but there is also an issue with the lock/latch. It literally has to be slammed shut for it to be closed properly. if u do it gently, it does not shut - its like its locked and hitting the bar of the mechanism. any ideas?? TYIA |
12-21-2018, 03:00 AM | #2 | |
529
Rep 2,503
Anyway, Have you checked the wiring running from the vehicle into the boot lid? They are enclosed in a rubber conduit. Often the wires inside become damaged and make the boot go crazy. Cut the rubber tube vertically / pull the rubber conduit right down and have a good look at the wires. |
12-21-2018, 04:57 AM | #3 | |
Rep 2
Thank you |
Tags |
e90 |
