12-18-2018, 08:54 PM | #1 |
41
Rep 91
LED foglights glowing when car is off
I put in LED foglights last summer, and I would occasionally notice that they would glow after the car was off (faintly, but visible). They would eventually shut off, however. Tonight, I noticed that my fogs are still glowing, hours after I shut the car off. They're far from full strength, but they're much more noticeable than they were previously.
I do have a battery charger connected to the car while it sits in the garage, so there's a chance that this is causing a weird electrical issue that is causing them to glow. Does anyone have any other thoughts about what might be causing this? Is there anything I can do to get them to shut off completely? Thanks, Jeff |
12-18-2018, 09:28 PM | #2 |
8243
Rep 16,082
I didn't have that problem, but mine did flicker as soon as I unlocked the car, even though the lights were not turned on, despite having ballasts and all the required coding. Adding resistors fixed it. I used 15 ohm, not the usual 6 ohm, as 6 ohm draw too much current when the lights are on, which can toast the wiring. All of my lights are LED, but only the fogs had this odd behavior.
12-18-2018, 09:30 PM | #3 |
2465
Rep 5,457
Drives: F30
Mine do this too. At first I was a touch concerned but that was months ago!
I believe it has something to do with the LED storing a bit of energy and glowing until that energy is spent. I'm coded and have no flickering. Never had a battery issue. I'd say you are fine. |
12-18-2018, 11:05 PM | #4 |
1996
Rep 2,499
I highly doubt this will drain your battery. An electrical load can only receive current. It cannot pull it from an open switch.
If I had to guess, there is a very small current in the electrical system from some type of sensor or ECU to check if the bulb is intact. It would do this by passing a very small test current through the lights and would warn you that the bulb was out if it didn't sense it coming back. Since LEDs are so sensitive/efficient, you will see them glow with a very small amount of voltage and current. If you want to prevent this, you could wire in a resistor to block off that current, but that's probably not necessary. You definitely do not have to worry about draining your battery though. |
12-19-2018, 07:16 AM | #5 | ||
8243
Rep 16,082
12-19-2018, 05:45 PM | #6 | |
1996
Rep 2,499
