12-18-2018, 01:51 PM | #1 |
Rep 8
ActiveHybrid3 Speakers Not Working
Hello everyone, long-time lurker, first-time poster.
We have a 2014 ActiveHybrid3 - a few weeks ago the speakers started cutting in and out and then went completely dead. Not even the seatbelt chime, etc but the display looks like it's playing. When I went to check the battery I noticed a large amount of fluid that the lower battery was sitting in. Not knowing what it was, I took it to the Stealership who said that it was just water and they wanted $2500 to get the water out and take apart the entire trunk and test every component. I took it home and shop-vacced out most of the water, rigged up my wife's old breast pump to get the rest out of nooks and crannies and loaded the trunk up with dessicants. All the water and moisture is now gone, and I have checked every fuse listed that's related to speakers or stereo system and they're all good. What should I check next? I have a multimeter and am fairly competent with this sort of stuff but I'm not that advanced. |
12-20-2018, 04:44 PM | #3 |
4488
Rep 10,473
12-20-2018, 06:05 PM | #4 | |
Rep 8
I haven't been able to replicate water getting in the trunk, only thing I can think of is that it got accidentally popped while outside. No idea how it would have happened otherwise. |
12-20-2018, 06:25 PM | #5 | |
4488
Rep 10,473
12-20-2018, 06:27 PM | #6 |
Rep 8
12-20-2018, 06:29 PM | #7 | |
4488
Rep 10,473
I suspect ISTA would be needed to test. As water and electronics do not mix, I’d guess that the amp is dead. I’d buy a used amp off eBay with 30 day return and try that. Return it if not the answer. Considering what Dealer will charge you for new amp..... |
12-21-2018, 07:32 AM | #8 | |
Rep 8
Might just try the new amp and see what happens. |
12-30-2018, 05:43 AM | #10 |
238
Rep 878
What about the water getting in, have you sorted that?
01-02-2019, 09:49 PM | #13 |
4488
Rep 10,473
